j wont astra 0cdti 2 start
Astra J 2.0cdti Wont start
Hi Just broken down my Astra J 2.0 Cdti stopped at lights then would not start. It turns over and seems to catch but then turns over more quickly but will not run. I checked to see if the starter still turns the engine when it goes more quicker and it does......anybody had similar not sure if its electrical or mechanical?
Has the cambelt snapped?
Hi the story has progressed since my post. After approx 3 hours got in it and it started so ran it for about the same distance it did the time it broke down, stopped it and restarted all seems fine. The only issue is tickover is a little erratic so cleaned the MAF and it seems more stable....know this is not my issue, but going to run it and see what happens. Very strange the way it turned over slow then fast but its ok now maybe crank sensor? unless anybody has had this before.
  Astra J manual – pedal box gone? pretty expensive! Mr Writer 5 12,398 9:th-Sep-2021, 14:27:28
Last Post: Gav-Astra
  weird motor sound Astra J 1.4 turbo oliv.cleiton 2 2,070 18:th-Jul-2021, 08:17:49
  Astra A17DTF - Timing Belt or Chain? everson38 1 1,586 17:th-Jun-2021, 12:03:07
  Astra j mirrors Kiel0777 2 2,158 15:th-Apr-2021, 20:34:53
Last Post: Kiel0777
  Astra won't start after some sensor cleaning? momoomar 2 3,261 3:rd-Oct-2020, 02:04:44
Last Post: momoomar
  Astra J 1.6 A16XER (115 hp) 2010 Outer Belt (and perhaps Timing Belt, too Acond 1 3,191 14:th-Aug-2020, 14:35:21
  Changing Rear Shock Absorbers. Astra-J Hatch. Replace or reuse bottom bolts? Big Dave2 5 5,230 22:nd-Jun-2020, 11:35:40
  Astra J 2011 1.7Cdti Juddering in higher gears Mark72 6 5,361 10:th-Jun-2020, 10:08:54
Last Post: Mark72
  Astra 2.0cdti dpf regen info? Boroboy 19 21,757 5:th-May-2020, 14:22:14
Last Post: Kiel0777
  2013 Astra J SRI Galway11 2 4,025 29:th-Jun-2019, 20:20:47
spukemonkey (21:st-May-2023, 20:41:18)
