0)
Threads: 36
Thanks Received:
0 in 0 posts
Car: Vectra
Sex: Undisclosed
22:nd-Dec-2016, 11:32:35
(This post was last modified: 30:th-Jan-2017, 12:42:16 by Rusty2009.)
Im suspecting its the front Drop Links/Stabiliser Rod...
Would anyone agree/disagree?
Also, seeing as ECP have up to 69% off, im thinking about ordering a couple.
There are 4 brands available, are they all about the same or is there any that I should avoid?
Q-Drive;
Lemforder;
OCAP
TRW.
Many thanks,
G.
0)
Threads: 36
Thanks Received:
0 in 0 posts
Car: Vectra
Sex: Undisclosed
Guys, need some help.
Changed the drop links on the weekend but still im getting that same noise. Where do I look now?
4)
Thanks Received:
4 in 4 posts
Are you sure it's the front I know alot of time a noise you think is coming from the front isn't.
0)
Threads: 36
Thanks Received:
0 in 0 posts
Car: Vectra
Sex: Undisclosed
Deffo sounds front, almost when you go over a little bump or stone, you hear like a wobbling sound. On straight surface its perfect. Sounds like drivers front.
0)
Threads: 9
Thanks Received:
0 in 0 posts
After a little read up on google it seems the knocking can come from the wheel arch liner knocking against the wings or strut top mount/bearing or worn strut.
0)
Threads: 36
Thanks Received:
0 in 0 posts
Car: Vectra
Sex: Undisclosed
Could it be anti-roll bar rubber bushes?
0)
Threads: 36
Thanks Received:
0 in 0 posts
Car: Vectra
Sex: Undisclosed
4)
Thanks Received:
4 in 4 posts
Best thing to do is get it up in the air and have it all looked over and checked for any play in bushes etc.
0)
Threads: 200
Thanks Received:
0 in 0 posts
6
Car: Astra J 1.7 CDTI
Yanno what... My car seems to be doing something similar! More of a distant rattle though from somewhere in the front but only when going over bumps
Sent from my STV100-4 using Tapatalk
0)
Threads: 36
Thanks Received:
0 in 0 posts
Car: Vectra
Sex: Undisclosed
Any ideas what it could be anyone? Could it be ARB bushes?
0)
Threads: 11
Thanks Received:
0 in 0 posts
It could be your brakes. I had this problem. Find a road where it does it, drive over without your brakes pressed, drive over it again with you brakes pressed slightly and see if it makes a difference. Vauxhall changed the caliper carriers for an updated version and it fixed the problem. Basically the pads were rattling in the caliper over rough roads but with the brake pressed it stopped. Hope this helps
