Uneven Road Surface and Getting a distant knock from the front....
Im suspecting its the front Drop Links/Stabiliser Rod...
Would anyone agree/disagree?
Also, seeing as ECP have up to 69% off, im thinking about ordering a couple.
There are 4 brands available, are they all about the same or is there any that I should avoid?
Q-Drive;
Lemforder;
OCAP
TRW.
Many thanks,
G.
Rough idling + knock isuses
Hi, just hoping someone has any thoughts on a rough running issue. The car is a 2015 Astra J GTC SRI with the 2.0 diesel (A 20 DTH). Everything was fine before the last service 3 weeks ago, since the service the idle from cold start is rough with fluctuations of 50-100 rpm and when it's particularly bad there is a knock from the engine almost as though the timing is being advanced.
[color=#333333]The issue is at it's worst in hot weather but can occur at any time from a
