a road knock distant the and surface uneven from getting front
Uneven Road Surface and Getting a distant knock from the front....
Im suspecting its the front Drop Links/Stabiliser Rod...
Would anyone agree/disagree?
Also, seeing as ECP have up to 69% off, im thinking about ordering a couple.
There are 4 brands available, are they all about the same or is there any that I should avoid?
Q-Drive;
Lemforder;
OCAP
TRW.
Many thanks,
G.
Guys, need some help.
Changed the drop links on the weekend but still im getting that same noise. Where do I look now?
Are you sure it's the front I know alot of time a noise you think is coming from the front isn't.
Deffo sounds front, almost when you go over a little bump or stone, you hear like a wobbling sound. On straight surface its perfect. Sounds like drivers front.
After a little read up on google it seems the knocking can come from the wheel arch liner knocking against the wings or strut top mount/bearing or worn strut.
Could it be anti-roll bar rubber bushes?
Best thing to do is get it up in the air and have it all looked over and checked for any play in bushes etc.
Yanno what... My car seems to be doing something similar! More of a distant rattle though from somewhere in the front but only when going over bumps
Sent from my STV100-4 using Tapatalk
Any ideas what it could be anyone? Could it be ARB bushes?
It could be your brakes. I had this problem. Find a road where it does it, drive over without your brakes pressed, drive over it again with you brakes pressed slightly and see if it makes a difference. Vauxhall changed the caliper carriers for an updated version and it fixed the problem. Basically the pads were rattling in the caliper over rough roads but with the brake pressed it stopped. Hope this helps
  Retrofit front parking sensors (GTC) pedroc1999 4 6,301 8:th-Apr-2025, 22:18:56
Last Post: johnny77
  Lowering springs identify front rear martinpe68 1 4,145 12:th-Sep-2021, 15:22:37
  Uneven idle and hunting on initial start up Jpbroad1970 2 5,880 24:th-Aug-2021, 09:34:41
  Front PDC wiring diagram milozic 1 8,152 2:nd-Feb-2021, 09:33:19
  Front suspension knock????? Sri~mike 10 15,049 22:nd-Dec-2020, 10:21:36
Last Post: M222RJF
  VXR Front Bumper onto a 5dr Bear 2 6,516 3:rd-Oct-2020, 11:48:59
  2017 GTC Limited edition - Front wheel noise Nathan191210 4 6,593 12:th-Jul-2020, 07:37:10
  Gtc 2017 1.4t 120 front brake disc size Nathan191210 2 8,344 25:th-Apr-2020, 07:41:05
  Can You Add Front Fogs to an Astra J? SAMW98SO 2 9,483 10:th-Apr-2020, 13:29:58
Last Post: SAMW98SO
  No sound on indicators, seat belt warning and quiet front parking sensors mpotsb 4 13,859 22:nd-Feb-2020, 19:24:53
Last Post: mpotsb
