battery lights off no dash or instruments
No Dash Lights or Instruments / battery off
I have just fitted a tow bar wiring kit to my gtc 1.4
I took of the negative battery connection.
Added the wiring as per instructions now when i start the car i have no dials or lights on dash no sat nav nothing as if a fuse had blown but they are all in order. I undone the wiring but this has not cured the problem.
Could this be down to the battery being off or is it more drastic.
If it is the battery can i do a simple fix ie reset or is it a case of in to the dealership :(
there should be two fuses for the display
  Reversing lights AndyF79 4 3,394 12:th-Sep-2019, 12:37:51
Last Post: AndyF79
  Service ESP/battery draining Derekjwhite 7 10,070 17:th-Apr-2018, 20:40:36
  ASTRA J CONDENSATION IN FRONT AND REAR LIGHTS! LukeAstra15 7 8,249 9:th-Jan-2016, 18:45:36
