??? amp ecu hi low power
ECU - HI POWER & LOW POWER ???
Γεια σας παιδιά.
Το αυτοκίνητό μου Astra J Sport Tourer 1.7CDTI 125bhp.
Κωδικός κινητήρα: A17DTR
Μια ερώτηση?
Στην ECU (BCM)  του αυτοκινήτου, έχει δύο επιλογές.
Γεια σου ισχύς του κινητήρα & Χαμηλής ισχύος του κινητήρα.
Τι είναι αυτό???
Για να ενεργοποιήσετε HI ισχύς του κινητήρα ???
Hi Guys.
My car Astra J Sport Tourer 1.7CDTI 125pchp.
Engine code: A17DTR.
A question?
The ECU (BCM) of the vehicle, has two options.
Hi engine power & Low engine power.
What is this???
To turn HI engine power ???
Thanks a lot.
(10:th-Dec-2015, 08:55:02)GEORGE Wrote: Hi Guys.
A question?
What is this???
Thanks a lot.
welcome to vxoc
how did you see that option what are you using opcom or mdi
Welcome, never knew an option like that was available :/
(10:th-Dec-2015, 08:55:02)ΓΙΩΡΓΟΣ Wrote: Γεια σας παιδιά.
Μια ερώτηση?
Τι είναι αυτό???
(10:th-Dec-2015, 11:08:02)tucpal Wrote: welcome to vxoc
how did you see that option what are you using opcom or mdiOp-com
My frieds or OP-COM.
What is this?
George see that option with my mdi on bcm menu when I was playing with mdi and it has two options increase horse power level1 or decrease horse power level1 his car was imported from Germany to Greece and it was the first car that I saw this option unlocked. I don't know if it really do something this option never tested. Sorry for his English he is using translation.
(10:th-Dec-2015, 20:06:25)z8083 Wrote: George see that option with my mdi on bcm menu when I was playing with mdi and it has two options increase horse power level1 or decrease horse power level1 his car was imported from Germany to Greece and it was the first car that I saw this option unlocked. I don't know if it really do something this option never tested. Sorry for his English he is using translation.
Is there anybody who have ever test that option?
Thanks a lot
Can i look for this option with op-com (clone).If yes in which menu?
this may be to do with the emissions or a BHP limit for Grease
if so the ECU may be programed to meet your standards in Grease
so if you have the option you may be able to increase the BHP to europe standards
theres only one way to find out increase it and see what happens
I've not seen this option on any BCM / ECU here in the U.K and I've plugged onto a fair few J's now.
The ECU/BCM was unlocked. In the menu , programming of the engine, there are the two options: 1) High Power Engine , 2) Low Power Engine.
What can these options do in the engine? What do they mean?
Is there anybody who have ever seen these options in OPEL ASTRA J 1.7CDTI 125ps?
Thanks a lot , George . Greece
You could Opel and ask them direct.
I called at opel.gr and do not they know.
  Max wattage on aux power? umognog 1 3,768 13:th-Jun-2020, 08:21:03
  Power for Dashcam and Mysterious Fuse GDM123 3 7,669 27:th-Feb-2016, 09:35:58
  Dash cam power supply Nickmagicfingers1981 1 6,567 30:th-May-2015, 19:52:14
