ECU fuse or fuses??
does anyone know how many fuses are fitted in the fuse box for the ECU on the 5-door J? am I right in thinking its fuse no.1 and fuse no.15?? anyone know why two fuses are referenced???
ECU - HI POWER & LOW POWER ???
Γεια σας παιδιά.
Το αυτοκίνητό μου Astra J Sport Tourer 1.7CDTI 125bhp.
Κωδικός κινητήρα: A17DTR
Μια ερώτηση?
Στην ECU (BCM)  του αυτοκινήτου, έχει δύο επιλογές.
Γεια σου ισχύς του κινητήρα & Χαμηλής ισχύος του κινητήρα.
Τι είναι αυτό???
Για να ενεργοποιήσετε HI ισχύς του κινητήρα ???
Ecu identification
Hey All,
Does anyone know how to find out what brand ecu I have? Apparently it can be one of two brands.. One is a denso and the other hand as something like ACdelko
ECU Remap or Pedal Box
I have 1.4 GTC and looking to improve it. I cant decide either to have a remap or buy a pedal box.
any advice?
2.0cdti ECU update for DPF causing poor fuel & loss of performace
So when my car had Turbo issue's the dealership did a software update to the ECU.
This update is related to the DPF
Quote:It adjusts the parameters for the dpf temperature sensors to improve dpf performance and avoid overloading dpf, eml lights and in worst cases engine stalling.
it's a software weakness that only effects astra j, cascada and zafira tourers up to model year MY13.5. The update will just adjust the software weakness that is present.
At first I didn't notice
DPF Drill & ECU Remap - thoughts please.
Guys,
I keep getting the message on the dash every few weeks on the Astra CDTI 20111 saying DPF full, continue driving.
My thoughts are to sell the car and get a petrol, but we like the car and waited ages to find the right one. So I have been speaking to a local garage who did a DPF removal and Remap on my mates BMW X5.
Basically, the guy at the garage said they wont remove it on the J, but they drill holes in the filter, and then re-map the ECU. All in £350.00.
Whats your thoughts
Cant connect to ECU
Hi guys,
To cut a long story short, I bought a bluetooth OBD2 reader to get a fault code read, app said it couldn't connect to my ECU it also sent loads of warning lights away and the rev counter starting going between 1000rpm and auto start/stop, so I sacked it off as cheap kit and took my car to a local garage to have the fault code read and when the code reader was attached to the OBD2 port it also couldn't read any fault codes.
Does anyone have any ideas about this?
I've checked al
ECU Updates?
Just purchased my car and despite having a full service history it has never been to a Vauxhall garage in the 6 years it's been registered. I use a trusted independent garage who will be doing all the future work on it but I'm wondering does it need at least one trip to Vauxhall for software (ECU) updates or anything like that?
Technical Service Bulletin 3141 ECU update
Hi folks, new to the forum. I have an Astra GTC SRI 1.4 with an engine warning light issue.
My garage told me that after consulting their Technical Information Supplier with the fault codes, that it needed an ECU update in response to Technical Service Bulletin 3141.
I've just taken it into Vauxhall Wakefield and their service team have done 'an' update, but have never heard of Technical Service Bulletin 3141, so won't confirm whether or not it has fixed the warning light issue.
Does any
ECU 1.7 CDTI 2012 96kw
Hi There,
I search on this forum about this issue, i don't know if it's common or not i couldn't find any answer.
I own an Astra J Hatchback 1.7 CDTI 96kw 131hp 2012 (A17DTF) with ECU ACDelco AA6P 55584315.
I got 2 main errors prompted on OPCOM and also on other diag tools.
P261A -- Low voltage on Auxiliary Water Pump Circuit (this was the first time i diagnosticated the problem on a service with a delphi tool)
P067A -- cylinder*4 glow plug control circuit low voltage
Additional
