power? max aux wattage on
Max wattage on aux power?
I've currently got usb power points front & rear, which output 2.4A@5v, but I'm looking at investing in the following:
Change the front to:
Move 2x 5v2.4A to hidden supply for a BT receiver & wireless charging point supply.
Add 1x 5v3A QC3.0 + 1x usb PD 30W charging point to centre console.
Change the rear to:
2x 5v2.4A (basic phone charge points)
Add 1x 5v2.4A + 1x usb-C PD 12v2A (max 30W)
Basically, I'm looking at adding 3 additional PD USBC ports for powering Nintendo switch(es) etc. Plus adding a pd phone charger to the front for super fast charging.
Reality is, I could potentially be drawing about 110-120W off of the 12V aux power line.
What is the max of that supply? 10A fuse?
20A fuse.
There is a fuse for the front and the rear both protected by a separate 20AMP fuse.
  Power for Dashcam and Mysterious Fuse GDM123 3 7,668 27:th-Feb-2016, 09:35:58
  ECU - HI POWER & LOW POWER ??? GEORGE 13 24,800 23:rd-Dec-2015, 07:44:06
Last Post: GEORGE
  Dash cam power supply Nickmagicfingers1981 1 6,565 30:th-May-2015, 19:52:14
