power supply cam dash
Dash cam power supply
Ok so after some twerp decided to cover my windscreen and bonnet with tomato sauce while I was at work. I am now looking at dash cams,
I have found this one on ebay http://www.ebay.co.uk/itm/251749193955?_...EBIDX%3AIT.
With it having the function to constantly record and has a battery drain prevention device I just wondered if I would be able to wire it into the lights in the roof instead of running down the a pillar/door.
Don't know if the roof light will have the power there once the door is closed.
You might be better using an empty fuse slot as most are constant live.
  Max wattage on aux power? umognog 1 3,807 13:th-Jun-2020, 08:21:03
  Power for Dashcam and Mysterious Fuse GDM123 3 7,747 27:th-Feb-2016, 09:35:58
  ECU - HI POWER & LOW POWER ??? GEORGE 13 24,966 23:rd-Dec-2015, 07:44:06
Last Post: GEORGE
Requan (8:th-Aug-2025, 14:13:52)
