Cam belt. .
What is the recommended mileage , at which the cam belt should be changed on the 1.7 CDTi diesel. .
Dash cam power supply
Ok so after some twerp decided to cover my windscreen and bonnet with tomato sauce while I was at work. I am now looking at dash cams,
I have found this one on ebay http://www.ebay.co.uk/itm/251749193955?_...EBIDX%3AIT.
With it having the function to constantly record and has a battery drain prevention device I just wondered if I would be able to wire it into the lights in the roof instead of running down the a pillar/door.
Go Pro Dash Cam
Hey guys Smile
So I'm planning on using my partners Go Pro as a dash cam and was just going to stick it to the windscreen just a bit below where the rear view mirror is...anyone think this is a good place to put it or does anyone else use one for this (or use dash cams in general) and know of a better place to mount it?
dash cam as a reversing camera
a guy in halfrauds said that if you get a high enough spec dash cam for boot you can get it to relay to the cars screen (if fitted lol) when in reverse, does that sound right,
its a shame you cant get a reversing numberplate lamp that is also a boot dash cam
Cam belt cost
Hi all, only had the gtc for 3 weeks now and loving every minute of driving.... I'm on 72000 miles now and a cam belt change isn't too far away ( I do 2000 miles a month ) ... It's a 2.0 cdti on a 12 plate
Roughly how much does it cost to have them replaced , when I had an Audi A3 it was good practice to have the water pump and tensioner a replaced at the same time .....is it the same with the VX ?
Cheers James
reversing cam
I've just ordered a b5754 and i want a reversing cam witch one would you recommend
Dash cam on Android unit
Hi, I'm a noob here, I'm picking up a 2012 Astra Elite on Saturday.  I've been reading a lot about replacing the CD400 with Android head units, which sounds good to me as I'd like Bluetooth and DAB.  I've been given a dashcam recently (Nextbase Duo HD) but I've seen that you can add cameras to the Android units.  Is this as good as having a separate dashcam, and can you also use the rear camera as a reversing camera?  Thanks!
Dash cam recommendations
Looking to get a dash cam due to how many idiots I have to contend with each day!
Any recommendations? Thinking front and rear would be a good idea?
Auxiliary Belt failure - cam belt change question
Hi all, I bought an Astra 2.0 CDTI recently and they fitted a new cambelt and waterpump as part of the sale. Just 2 weeks after getting the car the auxiliary belt shredded and snapped on the M11 and subsequently the brakes, power steering and just about every other light came on on the dash before the battery lost charge and it died. The garage I bought it from took the car back and put a new aux belt and battery in under warranty. They said the reason the belt snapped was due to a lose pulley b
