Thanks Received: 4 in 4 posts
4:th-Jun-2015, 07:29:35
(This post was last modified: 5:th-Aug-2017, 14:16:07 by Rusty2009.)
How-to remove roof aerial
So start by opening the boot and removing the parcel shelf (this is so you don't lean on it and brake it.)
Next start to pull the roof liner down from the rubber.
Then you need to unplug the fraka connector (it will be attached roughly where you see it in this pic)
To unplug them you will need to feel for the push tab.
Then push the back end down and with the other hand pull apart.
Next job is unbolt the aerial.
It's a 10mm bolt on the factory masts.
Now you need to push the push tabs in each side and push upwards, (having an extra person here can help).
14
Threads: 1
1
Car: Astra J
I would like to change mast with shark fin on my J.
Do I need something else or just change them?
There are many different part numbers.
Three without 'phone' or 'gps' cable/option:
17 84 024
17 84 034
17 84 063
Which one is the right one?
I need it for the cd600.
Thanks.
Threads: 1
1
Car: Astra J
16:th-Feb-2016, 10:57:50
(This post was last modified: 16:th-Feb-2016, 10:58:22 by Jerry.)
@Rusty2009 maybe you can help me which part number for the shark fin should I order (my post above).
I don't have gps neither phone installation in my car. The radio is CD600.
Thanks mate I know you are busy I have read in the other post.
Hi @Jerry sorry I was meant to look up them part for you and check.
I'll do it ASAP for you.
Just had a quick look on my phone none of them part numbers do FM/AM
Which I'm guessing is what you want?
14
They do not do a factory shark fin for fm only GPS and phone
Threads: 1
1
Car: Astra J
16:th-Feb-2016, 12:40:11
(This post was last modified: 16:th-Feb-2016, 12:41:45 by Jerry.)
Yes, I need for FM.
All three are wrong then?
In Opel shop told me I will have worse reception with shark.
They have no answer on my remark why some models have factory fitted shark.
Anyway I decided to mount it.
I have searched in other posts but didn't found part nr. for genuine shark fin.
(16:th-Feb-2016, 12:19:11)tucpal Wrote: They do not do a factory shark fin for fm only GPS and phone
I think I can use it just leave gps and phone wires not connected.
Right?
14
16:th-Feb-2016, 12:53:31
(This post was last modified: 16:th-Feb-2016, 12:57:52 by tucpal.)
What for just GPS ???? Fm and DAB are fitted on the rear window for how to do this look at DAB retro fit CD400 in the how to section that will cover how to fit FM to rear window so you can them have a dummy shark fin on the car but the factory shark fin will have no use as it is only used for satnav GPS.
There is not a factory fitted FM shark fin you would have to go aftermarket.
I will get the the links tomorrow.
If you pay the price the signal is better or same on the shark fin.
Threads: 1
1
Car: Astra J
Thanks mate.
Waiting for links.
Threads: 79
1
Car: corsa c
Sex: Other
24:th-Jun-2016, 12:21:47
(This post was last modified: 24:th-Jun-2016, 12:49:19 by mrtc.)
What fitting etc would you need for the Gps dab fm shark find aerial, is it really worth 150 quid, although I dont like the idea of a separate dab aerial and a GPS on the dash
Found this a lot cheaper, not as stylish but it does look oem I guess
https://www.driveden.com/car-audio-tech-...0wodEqcIVg
Wrong link lol, not got GPS lol
http://www.handtec.co.uk/c2-autoleads-da...0wodJOIJTA
The choice is yours mate I found with my DAB, FM/AM mast priced the same would drop out in places, yet my sharkfin doesn't drop out in the same places.
I would always recommend the sharkfin.
Threads: 7
2
Car: GTC Bi-Turbo
25:th-Apr-2018, 21:58:04
(This post was last modified: 25:th-Apr-2018, 21:58:36 by marktourino.)
Good Tutorial Rusty, change my aerial for a Hama Dab/Dab+ FM/AM aerial which works quite well, no drop out from the Dab signal as of yet & FM/AM signal is just as good.
Threads: 0
Car: Corsa D
Sex: Female
Hello guys. I was wondering if you can help me.
I want to fit in my corsa D a shark fin but I don't want the plastic ugly that GM has.
Is there any possibility for this shark fin from SAAB to be compatible?
https://rover.ebay.com/rover/0/0/0?mpre=...3336278698
Thank you very much.
(10:th-Sep-2019, 13:02:37)Despoina-Varypati Wrote: Hello guys. I was wondering if you can help me.
The Sharkfin is for Phone and Navi according to a part search.
If the aerial fitting on the corsa is the same as the Astra-J it should fit.
Threads: 0
Car: Corsa D
Sex: Female
I really dont know if it the same.
My car doesn't have phone but I think that is has navi. Can I plug only the one cable for the navi and the radio or it will not work like that?
Thank you.
Στάλθηκε από το SM-G965F μου χρησιμοποιώντας Tapatalk
