to remove reflectors bumper how rear
How to remove Rear bumper Reflectors
How To Remove rear bumper Reflectors
The best way to do this is to stick you hand up behind the bumper and feel for the two push tabs, as shown in the below pic.
Once you have found them push one in at a time and push it forward (towards the rear of the car).
and it will start to come out like so.
it would be a good idea to drill little holes in the back of the reflectors and fit some LED.s in them
and rig them up to the high level brake light
thanks a lot for this rusty!!!
tucpal Wrote:it would be a good idea to drill little holes in the back of the reflectors and fit some LED.s in them
Sounds good :P but would it be legal?
i don't see why it would be
here is a link but he rigged them up to the indicators
the high level brake light would have been a much better option
Looks good on the reflectors :-p
tucpal Wrote:i don't see why it would be
http://www.youtube.com/watch?v=J_dPoJcrPHg
Ooooo I live that idea. Someone needs to do it!
There is ruling for the positioning of brake lights they have to be 350mm from the groundalso in this country you have to have rear reflectors between 350mm and 900mm from the ground. Can't see the point in having so many brake lights.
good bit of info there baz
Like this mate
i may have a little play with this in the summer
tucpal Wrote:i may have a little play with this in the summer
How-to here http://www.vxoc.org.uk/forum/Thread-How-...reflectors
  Vxr rear exhaust fit to Diesel Afus1987 4 9,623 21:st-Mar-2021, 04:34:44
Last Post: M222RJF
  How-to remove roof aerial Rusty2009 17 36,634 11:th-Sep-2019, 10:28:43
Last Post: Despoina-Varypati
  How To Remove Rear bumper Rusty2009 17 46,874 7:th-Jan-2019, 18:18:25
Last Post: jamietomlin
  VXLINE bumper retrofit research tucpal 89 78,981 8:th-Oct-2018, 16:27:25
  How to remove Wing Mirror Covers, Astra j tucpal 12 38,656 5:th-May-2017, 20:37:31
Last Post: Tonto
  Vxr rear bumper fit to normal gtc Afus1987 3 10,245 8:th-Apr-2017, 09:24:18
  How-to remove Window trims & door mirrors Rusty2009 27 45,091 28:th-Mar-2017, 11:44:01
  How-to remove front bumper from Astra-j (MK6 5 Door Facelift) Rusty2009 31 74,731 28:th-Dec-2016, 22:58:13
  HELP: rear wheel arch dent removal Starie 4 9,987 8:th-Jul-2016, 22:45:33
  Front Bumper lower grille allymorrison70 2 9,344 12:th-May-2016, 23:01:33
Last Post: allymorrison70
