Trade Count:
0)
Threads: 1
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Sex: Undisclosed
Total Feedback: 0
Hello everybody.
I have changed the rear brake light bulbs to the LED bulbs philips and now every time i have a message that i need to check "stop" bulbs. Is it possible to turn off checking this "stop" bulbs?
Thanks in advance and sorry for my poor English.
Trade Count:
4)
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
I take you are asking if you can turn off the bulb checking?
If so no you can't, I'm sure you would rather know if a bulb was out rather than have a car hit you from behind?
The only way around this would be for you to install a load resistor or but the standard bulbs back in.
Trade Count:
2)
Threads: 220
Thanks Received:
0 in 0 posts
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
as rusty said the rear brake lights are on the canbus no canbus LED will cancel the errors
the only way to cancel the errors is to add a load resister between the wires
Trade Count:
0)
Threads: 1
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Sex: Undisclosed
Total Feedback: 0
Thanks for your answers, guys.
As you have said thre are two ways to solve the problem. One way is to use a load resister and the second way is to use a standard bulb between the wires.
I thought that it is possible to disable this function by OPCOM, am I right?
Trade Count:
4)
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Not as far as I know mate, the Op-com is still limited on the J.
