astra 13cdti 2010 drl
Drl Astra 13cdti 2010
Hi hope I've posted in right place? I have astra j 2010 my car only as indicators in my lamps and I have seen driving lights or fog lamps in some I want to no if I can sort something similar Help gratefully accepted Gazzer
You can retrofit the fogs if you want, also there is some aftermarket fog lamps that have a DRL and indicator in the bottom.
will get a link later.
Thanks for info Hope I don't come across as a total "l @@@ I'm not the sharpest pencil in the box and I may ask questions some no the answers to I've always had fords mainly st so some of the things seem to go over my head Any way I want if I can change my indicators for some type of indicator driving light that isn't guna mean endless questions So what would you recommend and point me in the right direction Thanks
  Astra J GTC IPC pinout.. pistnbroke 0 3,535 10:th-Apr-2021, 08:08:43
Last Post: pistnbroke
  How to remove sun visor Astra J GTC. MCG1983 2 5,792 21:st-Sep-2020, 10:52:43
Last Post: MCG1983
  Astra J wing mirror mreledil 2 5,409 10:th-Apr-2020, 09:50:17
Last Post: andyp
  Astra j cd400 upgrade to cd500 [emoji2] Astragalcreb 4 8,448 16:th-Mar-2020, 22:41:28
  Astra MK6/J can bus log/dump file astra.cluster 0 7,466 3:rd-Oct-2019, 10:19:03
Last Post: astra.cluster
  Astra J vin help pls :( Cossie 3 10,182 4:th-May-2019, 10:21:37
  navi 500 2009-2010 maps cd tzr608 1 8,342 27:th-Jul-2018, 07:59:00
  Astra J GTC 2.0 CDTi suspension entlio 3 10,876 30:th-May-2018, 08:32:57
Last Post: rlievens
  What are the specs for the wheel studs on a 2010 Insignia Sports Tourer? i.rosca 0 11,565 10:th-May-2018, 06:36:09
Last Post: i.rosca
  Astra J roof bars Gavinj87 0 7,616 13:th-Apr-2018, 20:21:51
Last Post: Gavinj87
