j vin help astra pls
Astra J vin help pls :(
I bought an Astra J 3 months ago and I was trying to locate vin number punched to the chassis. The Chassis number was covered in surface rust and I could see some numbers so I tried to remove rust with some sand paper and rust remover. Now I cannot see the numbers at all . Is there any product I can use to make the number reappear?
Sent from my ONEPLUS A3003 using Tapatalk
There is also a VIN plate in the windscreen
(3:rd-May-2019, 18:09:55)Rusty2009 Wrote: There is also a VIN plate in the windscreen
Ok but is that an Mot fail ?
They've only ever looked at the 1 in the widescreen when I have MOT.
  Astra J GTC IPC pinout.. pistnbroke 0 3,530 10:th-Apr-2021, 08:08:43
Last Post: pistnbroke
  How to remove sun visor Astra J GTC. MCG1983 2 5,786 21:st-Sep-2020, 10:52:43
Last Post: MCG1983
  Astra J wing mirror mreledil 2 5,403 10:th-Apr-2020, 09:50:17
Last Post: andyp
  Astra j cd400 upgrade to cd500 [emoji2] Astragalcreb 4 8,442 16:th-Mar-2020, 22:41:28
  Astra MK6/J can bus log/dump file astra.cluster 0 7,457 3:rd-Oct-2019, 10:19:03
Last Post: astra.cluster
  Astra J GTC 2.0 CDTi suspension entlio 3 10,873 30:th-May-2018, 08:32:57
Last Post: rlievens
  Astra J roof bars Gavinj87 0 7,615 13:th-Apr-2018, 20:21:51
Last Post: Gavinj87
  Astra j headlight repair kit workshop manual Cameron UK 4 13,388 18:th-Dec-2017, 19:41:33
  Astra J Rear Bike Rack Rlewis33 2 10,184 1:st-Jun-2017, 09:19:49
Last Post: Jerry
  Rear fuse box Astra sri 2014 bluenose50 2 7,033 18:th-May-2017, 22:27:39
Last Post: Jon_es
