automatic defog rear
Automatic Rear Defog
Is there someone to tell me how can i deactivate this setting with an op-com.I have already done this from the settings (config) of the CD player of the car but this continues to be activated by accident...
You wouldn't be able to do it from op-com, it may possible to disable with an MDI
Can you search if we could do this with a MDI and write here in which menu in the MDI can change this?
I'll have a look next time I do some programming not sure when that will be tho.
Take your time...
  Lowering springs identify front rear martinpe68 1 4,151 12:th-Sep-2021, 15:22:37
  Astra J Rear Bench Seat Clip. MrScottyMan 1 7,160 24:th-Jan-2021, 14:44:22
  Rear diffuser Elad1962 3 5,258 29:th-Sep-2020, 22:14:18
  BiTurbo Rear Bumper Dudderz 3 6,877 5:th-Jun-2020, 19:49:44
  Rear Bumper PN 13346637 Jonnymac07 1 4,030 13:th-May-2020, 14:56:05
Last Post: paula9568
  Rear brake pads and discs everson38 4 6,974 28:th-May-2019, 10:53:57
  electric rear windows marky79 5 7,485 11:th-Jan-2019, 09:04:32
  Rear Light Replacement (Need Advice) A.ROD 2 7,518 17:th-Dec-2018, 19:17:48
Last Post: A.ROD
  GTC water collects under rear window Canasta 2 7,283 30:th-Oct-2018, 22:23:04
Last Post: marky79
  Headrest for middle rear seat passenger benawhile 7 10,127 12:th-Oct-2018, 07:10:57
