lamp service afl
Service AFL Lamp
So whenever I drive for anything over 100m with lights on or off when I turn engine off or if the stop/start kicks I get an error message come up on the dash.
Service AFL Lamp and the orange AFL lamp stays lit.
Once I restart the car the problem goes away.
Saturday I had my MDI so when the error came up and was still displayed I plugged it on and there was no fault codes at all.
It's really bugging me now as I would like to know why it keeps coming up after long drive (never comes up for any trip under 100m).
I can't find anything on TIS about it.
were does the AFL and LED DRL lights
draw power from
when the engine goes off in start stop mode
probably they dont like being turned on and off so quick maybe
The DRL's draws power from the BCM, The AFL is fuse board.
It's just annoying that there is nothing stored fault code wise.
do you get the same error if you unplug the bulb
Not tried mate will later
Ok got the error come up after a 3 mile trip today, think I know what it is.
It came up when I was turning the steering wheel while putting the car in reverse.
I will test my theory out later.
hope you sort it
Well that theory didn't work tried to get the fault to come up again but nope.
think it may be to do with the corner lamps ?
you could have a loose pin after the retro fit somewhere.
I will check it all at some point
did not J1ODYA have this problem also ?
http://www.vxoc.org.uk/forum/Thread-Service-AFL
I've worked out why I'm getting this and have managed to reproduce it 5 times today.
It happens when you do really fast manoeuvres that is too fast for the lights can't coupe with.
  Service ESP/battery draining Derekjwhite 7 10,033 17:th-Apr-2018, 20:40:36
  Service vehicle soon? zaghloul 5 8,356 30:th-Jun-2017, 01:39:45
Last Post: zaghloul
  Radiator Fan and Service TAG Issue Roden 10 9,835 8:th-Jun-2016, 19:44:47
Last Post: Roden
  Service Park assist Kris 8 11,946 13:th-Jan-2016, 19:23:35
Last Post: Kris
  Service AFL J1ODYA 3 6,744 15:th-Mar-2014, 10:08:24
Last Post: J1ODYA
exhippykev (16:th-Jul-2023, 22:39:33)
