to remove wing j astra covers how mirror
How to remove Wing Mirror Covers, Astra j
How to Remove the Wing Mirror Covers
on the Astra J and will also Apply to the GTC.
It is best to use a Trim Tool for this job
take your Time and Do not be heavy handed.
Start at the Top of the Wing Mirror
take the Trim Tool and push it in between
The cover and the Mirror Housing
you can use your finger nails to get it started
there are Two Clips at the top.
Work you way along to the Corner
there is one Clip at the Edge.
Gently Pull the Cover away from the Housing
but not all the way off just yet.
Now use the Trim Tool and work
on the under side again there are Two Clips.
There is one more Clip to undo
and this is the Tricky one
lift the Cover so you can get the Trim Tool in
it is best to fold the Mirror in also this will help
and lift the Clip away with the Trim tool.
The Clip you are trying to get to looks like this.
It is very Possible to snap this one
but it will fit back just fine without it.
The cover will now be free from the Housing.
To Refit the Cover
do it in Reverse order.
Just be careful and dont rush
it is Possible to snap a clip if you are
heavy handed so take care.
Nice one mate not one I ever thought of doing.
Amazing thanks!! I will get some pics up asap!
just take your time
but as your wing mirror has had a knock
it may already possibly have a few broken clips
tucpal Wrote:just take your time
Thanks for this, here is a pic of the finished thing. Next is roof and rear bumper insert, unless I can get hold of the styling kit insert.
Looks good mate.
well done good job
there is a new one here
http://www.ebay.co.uk/itm/VAUXHALL-ASTRA...43cae5847c
cornishtaz has fitted one if you need help
tucpal Wrote:there is a new one here
Thanks mate I never saw this!
your welcome.
where do you get the trim tool from?
Great how to, will probably do this when putting in courtesy lights , hopefully without removing whole mirror ?
@Nemo
  How to Install a Reverse Camera in an Astra J with Navi 900 Summit 22 35,594 22:nd-Feb-2021, 07:59:27
  How-to remove roof aerial Rusty2009 17 25,339 11:th-Sep-2019, 10:28:43
Last Post: Despoina-Varypati
  How to fit a Front Grill Astra J tucpal 3 27,259 1:st-Mar-2019, 18:51:22
Last Post: blacknik
  How To Remove Rear bumper Rusty2009 17 34,760 7:th-Jan-2019, 18:18:25
Last Post: jamietomlin
  Multimedia interface, reverse camera, navi 600, insignia, astra j. tucpal 5 21,125 10:th-May-2018, 16:03:16
Last Post: vocky
  Inner Wing Lining removal help needed ed-b 4 4,903 15:th-Sep-2017, 03:27:03
Last Post: ed-b
  How-to remove Window trims & door mirrors Rusty2009 27 33,263 28:th-Mar-2017, 11:44:01
  How-to remove front bumper from Astra-j (MK6 5 Door Facelift) Rusty2009 31 49,176 28:th-Dec-2016, 22:58:13
  How-to remove fog surround Facelift Rusty2009 12 23,194 18:th-Dec-2015, 17:54:11
  HOW TO: De-Badge Rear and side of astra J Cameron UK 18 20,761 5:th-Apr-2015, 10:55:10
Arkanggel10 (6:th-Jul-2023, 12:19:34), livo (7:th-May-2023, 10:06:28)
