to sports lights tourer where open boot connect? flood
Sports tourer open boot flood lights - where to connect?
As my new car is for a dog's benefit, I'm keen to fit some led flood lights into the boot door so that when it opens, the immediate area underneath & behind is lit up like blackpool.
I'm looking at fitting up to 72W of led here, never mind dual boot lights & interiors coming on too.
I'm still looking at the position and placement of the floods, this could be simply 2 banks either side @36w or 2 banks either side at 18W plus a further 2 seated differently to light up further out from the car.
And suggestions on where to hookup for power would be good, as well as points for boot open detection? These will also be switched, requiring a combo of open + switches to switch on/increase.
Sound's interesting, I think I would run some off the boot light and the others off a separate feed which would be switched controlled.
It's the route in thinking of going - a lower power "puddle light" from the boot, and a separate switch high power flood, for when I need to see what I am doing.
Edit: with doing that, I think I would still use the boot light along with the switch, to prevent accidental "left on".
Via a relay would be a good way then.
Wired up something like this
Looking good. Will be scouting the trim tomorrow for good potential sites for the LED clusters themselves, then looking for the right units across the usual websites.
To be continued (quickly, those nights are getting dark, quick)
Thanks rusty for this info.
Looking at the trim last night & the flaps for accessing the rear lights might be a good option, or just to the side of them: just the right angle and position for lighting up the space immediately under the tailgate.
Still looking at the position of a second set.
Sorry for updating an old thread, But a few weeks ago i bought these little white panels from AutoBeam i think and they are supposed to be footwell LED's but i fitted two in the boot lid on the Meriva wired straight into the boot light, and they are great in the dark, nice spread of light around the rear of the back but also into the boot itself.
Wire went through the gator thing between the boot lid and the body and straight down the side into the boot.
Is that the 48 smd led panels?
  Boot trim clip leighton.read@sky.com 2 4,372 9:th-Jul-2020, 10:07:00
Last Post: leighton.read@sky.com
  puddle lights marky79 2 4,409 29:th-Nov-2019, 00:46:59
Last Post: Collster
  Rear registration lights LegendOfEagle 2 5,392 7:th-Feb-2019, 17:42:57
Last Post: LegendOfEagle
  Boot rubber thing part number Telsun 0 9,798 2:nd-Jan-2019, 21:07:37
  Wiring Diagram [Internal Lights] cubez0 3 7,159 25:th-Jun-2018, 11:28:03
  What are the specs for the wheel studs on a 2010 Insignia Sports Tourer? i.rosca 0 11,304 10:th-May-2018, 06:36:09
Last Post: i.rosca
  What is this part called? Boot latch cover thingy. rlievens 15 23,524 23:rd-Oct-2017, 13:36:58
  Footwell lights hungrydiscus 5 8,250 26:th-Apr-2016, 18:26:05
Last Post: hungrydiscus
