Where should I put it
Ok I'm buying a small amp
http://www.caraudiodirect.co.uk/kenwood-...0w-car-amp .
I'm debating where it should go.
I was thinking on the back of the rear seat or on top the flex floor but then it would get in the way if I lay the seats down to put a load in.
I was then thinking what about under the flex floor but I still think it will be in the way.
So I've thought about behind the side trim?
I'm sure Vauxhall fit the AMP behind the trim (on the right).
Thoughts
Tonto - Replies:
Where are you from ?
As the title says where are you from or based. I'm hoping to get a better idea of where our members are located for future events. So please comment either your town or city please.
CRNeo - Replies:
Where to buy genuine piaa DRLs?
One of my DRL bulbs has gone (again!) thinking of trying the piaa instead of the polargs but can't seem to find any decent places to purchase.
Anyone got any links?
Think found them in the lighting section... have ordered some up anyway so hopefully be fine.
umognog - Replies:
Sports tourer open boot flood lights - where to connect?
As my new car is for a dog's benefit, I'm keen to fit some led flood lights into the boot door so that when it opens, the immediate area underneath & behind is lit up like blackpool.
I'm looking at fitting up to 72W of led here, never mind dual boot lights & interiors coming on too.
I'm still looking at the position and placement of the floods, this could be simply 2 banks either side @36w or 2 banks either side at 18W plus a further 2 seated differently to light up further out from t
cubez0 - Replies:
Where to find standard head units
Hey all,
I have a '16 plate SRi, when i brought it has a DriveAuto head unit.
Does anyone know where I can find a 600/650/950 to put it back to standard?
I have been using a newer corsa for a bit and have found android auto enabled system to be perfect for me and i would like to go back to one of these standard units and use it?
Could only find this on ebay:
https://www.ebay.co.uk/itm/VAUXHALL-ASTR...?hash=item
Telsun - Replies:
Where's my thread?
Posted a thread yesterday titled "Got a GTC" which I was waiting to be approved (being a new member). My other posts from yesterday were approved but this one which was the lengthiest and the one I intended to be my project thread is nowhere to be seen!?
CAW - Replies:
Where to earth hardwire kit
I have bought nextbase hardwire kit and manage to to slip the wire behind both wires and air bag in the A frame of passenger side. (Not strong enough to pull the A Pillar trim fully with that metal clip in place).
I have threaded the wire down the inner door by removing the rubber sill and was going to the side where the fuse box in the glove compartment.
My question ... should I attach the earth (black wire) to a metal bar behind the glove box on one of the nut bolt (not sure if it
Where to find the engine code?
Hey guys,
Does anyone know where to find the code on a 1.7 Astra GTC diesel 62 plate? (Attached a pic of engine bay just f it is somewhere obvious)
Thanks in advance[Image:
https://uploads.tapatalk-cdn.com/2021061...f4fa98.jpg ]
