adjustment clutch gears grinding
Clutch adjustment/grinding gears
I've recently bought a 1.4t astra J. To me the clutch bite is way too low. I find myself trying to get through gears rapidly and grinding gears, especially 1st into 2nd. With the nature of the engine, it needs to be reved, but I find myself nervous of moving through the gears too much.
It may well be me, and the way I drive, but the clutch bites and disengages within the bottom inch of travel. Is this normal? Can it be adjusted at all?
Thanks,
Ben
I have a 1.3 CDTI and I've came from a car with an extremely high bite, so it was a bit strange to me also. I wouldn't say it's unusually low (for me anyway) although I do agree it's a bit of a race to change from 1st -> 2nd.
  AC Compressor clutch broken rlievens 2 4,154 19:th-Sep-2020, 19:01:39
Grinding rotating noise from GTC? MattDe123 2 6,176 1:st-Nov-2018, 10:30:33
Last Post: MattDe123
  Can't get in gear - clutch problem? klargon 0 5,033 9:th-Dec-2017, 16:21:11
Last Post: klargon
  Squeaking, whirring and grinding mw2299 2 6,848 11:th-Oct-2017, 06:41:07
Last Post: Straws
  Astra J Clutch pedal loose abba34 6 12,808 16:th-Sep-2017, 00:11:26
Last Post: slavenK
  Dry, almost grinding type noise from front wheels / discs area rbull51 2 9,258 12:th-May-2017, 11:17:58
  Astra Gtc 1.4t clutch problem Wayneofwolves 2 6,632 25:th-Feb-2017, 09:16:33
Last Post: Wayneofwolves
  Astra 1.6 clutch judder after being stuck in traffic tina r 3 11,881 6:th-Aug-2016, 23:13:10
Last Post: marcus
  Clicking clutch Nemo 12 14,322 2:nd-Mar-2016, 20:16:12
Last Post: bhalay207
  Top Gears reasonably priced Astra for sale bhalay207 4 7,466 23:rd-Dec-2015, 12:08:26
gemini6791 (12:th-Apr-2025, 01:06:10)
