door leds console
Door/console LEDs
Anyone know what type of leds are fitted in the door trim and centre console, as I'm being lazy and can't be bothered to remove the trim
Not a clue mate would be good to know incase I fancy a color change lol.
Exactly what I want to do fancy changing them to blue
I have blue in the rear so might try green or orange or something like that.
Cool
If only you asked the question week I had to help Lewis fit his so could of had a look and grabbed some pics for you.
I think a red would go better for mine
I found an old chavy geeky mod i had on my corsa the other day lol knight rider bar lol
Where in Swindon are you Lewis6317
Not the best pics but a couple of the LED on the center, there are two in this one each end.
door LED
CENTER CONSOLE LED
Thanks guys just been out and removed both parts, didn't need to remove door trim.
Think I've identified the gear surround leds as 4040 and door trim I think are 2828 both are very difficult to get hold if as there not common smd led
Not sure how you would de-solder them.
I've got access to very fine tip soldering irons if I can get new leds i'll give it a go
good man it will look good
I'll keep you all posted. Will take pics as well
cornishtaz Wrote:I'll keep you all posted. Will take pics as well
Top man, have you got the car all sorted now?
Rusty2009 Wrote:Top man, have you got the car all sorted now?
No mate goes in Monday for roof respray at dealer cost, stone chip warranty work and front bumper investigation. Getting a 1.6T GTC as a courtesy car
I bet you wish you kept the GTC now.
Rusty2009 Wrote:I bet you wish you kept the GTC now.
Sometimes yes until I start the VXR up
I received the 2 4040 leds for gear surround today, will fit it next week when I'm on late shift in work.
I need help identifying this LED I think it's a 3528 not a 2828
I think I saw them on a email from mouser will check tomorrow.
Nope I was wrong they were 3030.
I've found these.
3528 don't look the same though mate.
But they not 2828
The measurements of the above are 3mmx3.3mm measured with a vernier gauge. Looks like Vauxhall have used a odd size
Done some checks and the pins in the 4 corners are linked together and connected to the +ve legs the pin on the right is connected to -ve and the pin on left isn't connected to anything.
Mouser do the 4040 LED in red, green, yellow, blue, orange and they also list Grn 570nm 120mcd 120deg Water Clr
Manufacturer is Kingbright
Don't know if any of these are any good
Here is the catalogue.
Thanks mate will have a look
Got some leds sorted done the gear surround these were 4040 90degree smd's one at each end.
The door leds I used a 3528 and modified the pcb so they would fit.
Also done my spare window switches using 805's
Will get a how-to together once I get my car back
Cool can't wait mate.
like the sound of that i would love blue LEDS
Baz are these the right ones for gear surround?
Yes mate I'm currently putting a comprehensive how-to together along with LEDs to be used
Super he does other colours too just came across them.
Look forward to the how-to
  Vxr bumper on 5 door Astra j Sh4rk2007 10 14,543 6:th-Jun-2021, 18:25:04
Last Post: jeniferbitcoin71
  Diesel door wont opel Arkanggel10 2 3,968 13:th-May-2021, 15:31:33
Last Post: Arkanggel10
  door drain grommets bigbadkes 2 4,637 28:th-Aug-2020, 19:45:49
  1.6 cdti 5 door exhaust tip? h4r7y 1 4,494 17:th-Jul-2020, 06:47:38
  passenger door deadlocked celrx 3 5,785 15:th-May-2020, 15:29:46
Last Post: paula9568
  Door locking Flick19191 1 3,530 22:nd-Nov-2019, 09:40:18
  Replacing door check strap robk999 5 10,229 7:th-Feb-2019, 21:27:33
  Centre console Aux in question Mr_Benn 2 5,708 12:th-Jan-2019, 20:28:30
Last Post: Mr_Benn
  centre console / gearstick slider how to remove? lacesoutdom 3 6,853 10:th-May-2018, 07:41:01
  Astra J 5 door facelift bumpers Iaintruten 5 7,797 30:th-Oct-2017, 16:40:35
Last Post: Iaintruten
dongawron (2:nd-Feb-2026, 20:40:47)
