sensors wiper fluid coolant retrofit and
Retrofit Coolant and Wiper Fluid Sensors
Hi All
Just looking into the sensors I would need to retrofit in order to get the wiper fluid and coolant sensors working as I'm thinking I'd probably get some use out of this so it makes sense to use it rather than have those warnings removed all together. Would be a project for when I have more money but wondering if the following sensors are the ones I need?
13195945 - Washer fluid
13276326 - Coolant
Also do these just sit between the pipes and the actual tanks themselves or are they a little more complex to fit?
You need to replace the washer bottle and header tank mate as they have the holes in already (normally comes complete with the sensors too).
Balls :( ha. I've found the coolant tank (small clear/white tank)
[ATTACH]524[/ATTACH]
But can't find a washer tank with the sensor...
Have a few questions if you don't mind answering them to help me out:
Do you happen to know the part numbers for the two items I need?
Can I use tanks from different engine sized Js or do they have to be from the same type as mine?
Do they require any programming to work once installed?
IIRC they are all same mate.
I'll get you the part numbers later.
No they will after you have plugged them in, The one that could prove to a problem is the washer bottle plug as on Lewis one of the terms had corroded and broke in so I had to fix that.
Cheers dude! And hmmmm don't think I'd be tackling that one on my own anyway, would probably get someone to fit it for me. The coolant bottle looks easy enough though
The brand new coolant bottles on auto vaux are really cheap! Not sure if they come with the sensors though.
Edit: Spoke with Vauxhall and they have the coolant bottle for £22 and the washer fluid bottle (with separate sensor) for £52. Will have to buy them when I get money! Will add to the list for now lol. Just hoping my car has the connectors in place to plug the sensor enabled bottles into
Well this is odd! The garage have fit the coolant tank and showed me that it was all plugged in but it's still showing the low coolant message :-/ any ideas guys?
There shouldn't be any problems with corrosion, I'll check the wiring out once I can get into TIS.
Right Had a look on TIS mate I wonder if you have the wire on the IPC plug details to follow.
Cheers mate and would that be a wires to actually allow the car to communicate the coolant sensor info to the IPC itself?
Yes mate it runs from the coolant tank to the IPC no fuses etc.
Washer sensor
Here is the Pinout
Well you are there check for pin 29 as well.
If you do have the wiring the only other thing I can think is a wire could be broke or corroded most likely place for this will be at the plug or maybe even the plug is not fully connected.
You're the man! Thanks for this will try and have a look this weekend...this cluster spends more time out of the car than in it! Haha
Merhaba soğutma sıvısı düşük sensörü ipc pinout soketi
number?
[alıntı="sheppy1" pid='17460' tarih satırı='1427447554']
Sen adamsın! Bunun için teşekkürler, bu hafta sonu bir göz atmaya çalışacağım...bu küme, arabada olduğundan daha fazla zamanı dışarıda geçiriyor! Haha
[/alıntı]
Coolant low level sensor Ipc 29.pin?
  Retrofit front parking sensors (GTC) pedroc1999 4 5,047 8:th-Apr-2025, 22:18:56
Last Post: johnny77
  coolant pressure tester chuzzle359 0 2,931 14:th-Apr-2021, 18:23:08
Last Post: chuzzle359
  Coolant light coming on when coolant is full (new sensor and no leaks) baffling me! Brasseyebaby 3 6,862 2:nd-Feb-2021, 21:12:47
  Gtc 2017 1.4t 120 coolant leak Nathan191210 1 4,706 1:st-Oct-2020, 07:02:07
  No sound on indicators, seat belt warning and quiet front parking sensors mpotsb 4 11,928 22:nd-Feb-2020, 19:24:53
Last Post: mpotsb
  coolant tank hose ref needed alexy357 1 3,979 4:th-Mar-2019, 08:43:32
  Coolant is milkshake Ultraviolet 5 6,127 18:th-Dec-2018, 17:45:31
  TPMS Sensors on wheels but not on car AphoticSketch 2 5,249 7:th-Nov-2018, 17:01:44
Last Post: AphoticSketch
  SCR System retrofit MrLocke 3 4,903 8:th-Aug-2018, 07:31:38
  Slow coolant loss Dennis S 21 29,196 8:th-Jan-2018, 11:13:20
Last Post: Dennis S
4 User(s) read this thread:
Rusty2009 (5:th-May-2025, 19:32:51), Big Dave2 (8:th-May-2025, 12:54:06), dellpiron (28:th-May-2025, 21:05:51), j0bj0sh (4:th-Aug-2025, 05:54:59)
