2nd year service brake fluid change
I'm coming up to my second year service which if I'm right means the brake & clutch fluid need to be changed.
I know the dealerships don't do it but I have my service done elsewhere (as I don't trust the dealer) so to get my lifetime warranty reactivated would I really need to change the brake fluid?
Or should I just buy a bottle of it and get my mechanic to tick it as done.
Wiper fluid and coolant bottle sensors
Hi All
So I've finally got my new IPC working but wasn't able to disable the warning messages about the low wiper fluid and the low coolant levels. I can't afford to fit the bottles which have the sensors and have read and have been told that I can just bridge some connectors to stop them from appearing...what exactly does this mean and how would I do it?
Also would doing this disable the coolant temp that I see in the display or is this something else?
Retrofit Coolant and Wiper Fluid Sensors
Hi All
Just looking into the sensors I would need to retrofit in order to get the wiper fluid and coolant sensors working as I'm thinking I'd probably get some use out of this so it makes sense to use it rather than have those warnings removed all together. Would be a project for when I have more money but wondering if the following sensors are the ones I need?
13195945 - Washer fluid
13276326 - Coolant
Also do these just sit between the pipes and the actual tanks themselves or ar
auto transmission fluid change
right then,
my 1.6 petrol tourer has developed a leak from the transmission cooler pipe at the radiator end.
I have a new (genuine) connector/seal to fit, the pipe is NLA
but there will be an amount of oil lost during the remove/refit process plus the unknown quantity already lost.
rather than top up the fluid, I guess it would be better to change the fluid,
I've read the workshop manual instructions online which seems fairly straightforward until the part where it says
"the fluid le
