to install unit reverse wireless head android how camera
How to Install Android Head Unit + Wireless Reverse Camera
#51
Yes it's green and white... Sorry for the confusion
Deleted. Sorry. Me being an idiot. :/
(25:th-Feb-2016, 10:21:47)sheppy1 Wrote: For the reverse camera receiver you’ve just going to want to splice the red and black power and ground cables onto the small wiring loom that you’ve connected to the back of the had unit and you’re done! There is a blue cable marked “back” or something like that but you don’t need it. Just again tuck this out of the way somewhere.
Can I just check on the blue wire.
My understanding is that this is a input to the head unit.  It expects 12 volts when reverse gear is engaged, which forces the head unit to turn on, and select the reverse camera input.
I can see that the head unit might notice video arriving on the reverse camera input and select that, without the blue wire being necessary.  But does this happen if the head unit is turned off and you engage reverse?
Jonathan.
The head unit does indeed shoe the video feed even when the unit is off or still powering up
Does anyone know of an reverse camera option for the Astra J estate (sportstourer), like the one here that goes into the numberplate light ??
Sendt fra min SM-G930F med Tapatalk
i dont seem to be able to find one for the sports tourer so if you do let me know
(28:th-Oct-2016, 10:08:07)bunje Wrote: i dont seem to be able to find one for the sports tourer so if you do let me know
Sports tourer number Plate camera is very scarce . There was someone else back a few months ago who couldn't find one. Happy hunting.
Past 2008 Civic 1.8 Type S
Ok, good to hear it's not only meet who can't find one..
Good evening guys,
I am in a process of installing a camera, and the above write up is great!
So I am assuming the following process:
1. Pull the cables through to the boot ( done )
2. Connect the red wire into the green/white wire in the fuse compartment
3. Ground the black wire
4. Run the cables to the HU ( M072 for me )
One question though... what do I do with the short red wire on each end of the RAC leads?
EDIT: If I get the 12V from the above mentioned green/white reverse light wire is it likely that I will have problems with the CANbus ( flickering with ignition on etc. )?
Many thanks
Ignore the red wires on each end of the RCA cable.
No you won't have any problems.
Thanks Rusty!
I have just had a play with the wiring and to my suprise a voltage tester ( screwdriver with an led ) is not getting anything from the green/white wire.
Is this right?
On a closer inspection of the actual reverse light I can see that there are 3 wires going into it:
1. Green/white
2. Purple/white
3. Black
Kind of lost now...
UPDDATE:
Wired, conected & working but...
It is really out of sych somehow?!
What I mean is that I could be parked ON a line but the camera would indicate that there is still a fair amount of room between the car and the line.
Any ideas? The unit is M072 and the camera is a "carrover" make from amazon.
I don't know if there are any adjustments on the M072 unit for the camera.
With the factory fitted camera it shows you as being on the line when in fact you are about 5cm off it.
Thanks Rusty
Hi I have the 64 plate atsra ecoflex with cd400. Am wondering where I can buy the Android M072 Aftermarket Head Unit ? Am i right that this one has sat nav and bluetooth and usb ? And also Would it be a straight swap to connect the m072. Sorry for all the questions
  How To Fit Sub To CD400 Head Unit TUFFKNUX 138 180,504 20:th-May-2021, 09:19:58
Last Post: h4r7y
  How to Install aftermarket head unit Rusty2009 55 85,395 14:th-Mar-2021, 15:16:56
Last Post: GTC-Nut
  Android RV5754 factory settings password Amazingusername 3 6,168 7:th-Nov-2020, 16:08:03
Last Post: cro55m
  Battery drain Android tesla style head unit rayvo1 4 7,828 9:th-Sep-2020, 21:05:31
Last Post: rayvo1
  Sports Tourer DAB+ on Android Headunit MikeyP247 2 5,340 2:nd-Nov-2019, 17:11:28
  Dash cam on Android unit robk999 2 12,427 2:nd-Nov-2019, 10:30:30
  CD400 buttons not working Android head unit install mephisto 4 12,237 27:th-Oct-2019, 17:30:00
Last Post: mephisto
  Front DVR android S160 M072 NEATH-LAD 3 5,937 4:th-Jul-2019, 19:07:39
  after market head init marky79 0 6,991 4:th-Nov-2018, 17:17:12
Last Post: marky79
  Where to find standard head units cubez0 9 13,988 18:th-Oct-2018, 17:55:45
jakob17 (23:rd-May-2025, 12:17:56), salniish (23:rd-Jan-2026, 15:58:32)
