to where head units standard find
Where to find standard head units
Hey all,
I have a '16 plate SRi, when i brought it has a DriveAuto head unit.
Does anyone know where I can find a 600/650/950 to put it back to standard?
I have been using a newer corsa for a bit and have found android auto enabled system to be perfect for me and i would like to go back to one of these standard units and use it?
Could only find this on ebay:
https://www.ebay.co.uk/itm/VAUXHALL-ASTR...SwnntbnQIc
Any help would be appreciated!
You would need wiring changes and programming to make a Navi work, none of factory navi's have android auto on the J.
Hi guys just a quick question I have a 2012 Astra j 5 door with a Navi 600 head unit but it has no Bluetooth, could I just buy a factory by module and wiring loom and it will work or at I being abit nieve??
(17:th-Oct-2018, 08:28:38)Camdragon94 Wrote: Hi guys just a quick question I have a 2012 Astra j 5 door with a Navi 600 head unit but it has no Bluetooth, could I just buy a factory by module and wiring loom and it will work or at I being abit nieve??
The Navi unit would need programming so it knew BT was there.
Myself in Bournemouth or John in Northampton could program the Navi for you and supply and fit the BT module and wiring.
Hi Rusty that’s smashing do you know rough cost for of these??
BT modules can picked up fairly cheaply off ebay just need to make sure it comes with a bracket.
https://www.ebay.co.uk/itm/Vauxhall-Astr...:rk:7:pf:0
If you wanted loom, fitting and programming from myself,
To supply and fit loom £100 (custom made loom as you can't buy them separate from dash loom) to program radio would be £70 (this would also give you rear camera & DAB if you wanted to fit at a later date).
Hi Rusty,
Thanks for the information not as expensive as I though is it hard to do the DAB upgrade and rear camera as I think doing all at once would be best save doing two trips as I’m in Nottinghamshire
Regards
Cam
DAB module
https://www.ebay.co.uk/itm/VAUXHALL-INSI...:rk:1:pf:0
Rear camera on 5-door Hatchback & GTC is £170 supplied and fitted (again custom made loom).
If you want to go down the DAB route at the same I'd advise a roof aerial, best I've used (for sharkfin wise is Calearo or Celsus) of course you could use a windscreen mount one.
Hi Rusty
Thanks for the tips as soon as I have bought the modules needed I’ll contact yourself about the programming of the units and come down to you if that’s ok.
Thanks for all the help
May also end up wanting the LED Conversion too
(17:th-Oct-2018, 16:29:19)Camdragon94 Wrote: Hi Rusty
That's not a problem at all.
  How To Fit Sub To CD400 Head Unit TUFFKNUX 138 178,632 20:th-May-2021, 09:19:58
Last Post: h4r7y
  How to Install aftermarket head unit Rusty2009 55 84,373 14:th-Mar-2021, 15:16:56
Last Post: GTC-Nut
  Battery drain Android tesla style head unit rayvo1 4 7,742 9:th-Sep-2020, 21:05:31
Last Post: rayvo1
  CD400 buttons not working Android head unit install mephisto 4 12,137 27:th-Oct-2019, 17:30:00
Last Post: mephisto
  How to Install Android Head Unit + Wireless Reverse Camera sheppy1 64 69,248 9:th-Jan-2019, 15:07:53
Last Post: Shorty5
  after market head init marky79 0 6,960 4:th-Nov-2018, 17:17:12
Last Post: marky79
  What's the best dongle for a V5754 android head unit? johnboy999 11 23,729 12:th-May-2018, 20:36:07
Last Post: Alby75
  Android head unit stuck johnboy999 12 23,780 10:th-Apr-2018, 21:03:11
Last Post: johnboy999
  Android 8.0 V5754 Head unit questions mdruedal 0 6,464 22:nd-Mar-2018, 23:46:50
Last Post: mdruedal
  How to remove the head unit from the car includes Screen removal Rusty2009 9 30,439 28:th-Sep-2017, 19:00:13
