issue j fan cooling astra 2010
2010 Astra J - Cooling Fan issue
Hi, I’m having a problem on my 2010 1.6 Sri Astra J.
The cooling fan is running all the time, even on motorway driving, it won’t shut off.
I’ve had a diagnostic tester on and it flagged up the following code.
P0480 - Cooling Fan Relay 1 Control Circuit
So far I’ve replaced the following:
- the sensor at the bottom of the radiator
- the expansion tank (with sensor)
- the thermostat with built-in sensor
I’ve also checked the 3 relays for continuity and operation with 12v supply, and noted they all work perfectly off the car, which suggests when fitted one or more are receiving power.
I don’t have access to an electrical diagram for the cooling system, which is making further troubleshooting difficult.
Anyone have an idea what to do next?
I will try and get you some info tomorrow.
If not drop a message back here & I'll get onto it.
The following 1 user says Thank You to Rusty2009 for this post:
  • Madal101_uk
Hopefully these will help.
  P0480-1.pdf (Size: 80.61 KB / Downloads: 5)
  P0480-2.pdf (Size: 89.79 KB / Downloads: 4)
thanks, i’ll go over these at the weekend
  Astra J 2014 1.6 petrol, dashboard noise help Steve1982 0 1,091 9:th-Sep-2025, 08:39:49
  Astra J 2014. Electric static noise under dash Steve1982 0 1,018 8:th-Sep-2025, 21:22:49
  High pitched noise (Astra OPC J) maximame 0 7,056 24:th-Mar-2021, 08:34:13
Last Post: maximame
  Gear Knob issue (Automatic 2014 Astra GTC) DC23 1 8,227 22:nd-Feb-2021, 08:08:37
  Astra J. Can a tyre valve be replaced without replacing the TPMS? benawhile 2 7,926 5:th-Aug-2020, 12:33:14
Last Post: benawhile
  Astra GTC auto gear knob replacement Jayrich872001 12 31,918 22:nd-Jul-2020, 12:21:46
Last Post: DC23
  Astra J SRI 13 Plate - Radiator Fan Gavin1506 2 7,055 11:th-Jul-2020, 22:08:04
Last Post: Gavin1506
  Another blower issue.. Zcubed 25 29,750 4:th-Jul-2020, 13:19:48
  Astra J 1.6 CDTi increased fuel consumption _Mita 2 11,866 1:st-Mar-2020, 22:27:38
Last Post: _Mita
  Astra ST 1,6 CDTi, error code P0181 claymansvk 1 5,863 20:th-Feb-2020, 19:32:31
hobnobs (4:th-May-2025, 17:15:50), Happy25 (15:th-Jun-2025, 09:28:55)
