fan blow problem
Hi all
I am having problems with the blow not coming out the screen vents.
On changing the pollen filter check the selector as it's climate control, check the motor and they work just that the selector does not turn all the way to the screen post ion with out help.
have oiled it and helped buy still sticks, any idea how to free it up or any 1 had this issue before maybe ?
Simon
Khaled - Replies:
Cooling Fan Strange Behavior
Hi guys
, hope someone have a clue on what happening with my car
Sometimes the cooling fan won't stop, and others it just blow for few seconds as i turn on the ignition, and sometimes it just work fine, also have a message ''Car service necessary'' pop out with the strange behavior of the Fan
the car is a 2012 1.6 turbo with just over 30000 miles on it.
Thanks for help
sheppy1 - Replies:
Astra GTC Fan Alloys
Looking for a set of the GTC Fan style alloys with tyres (half worn or better) for around 350 to 400. Anyone selling any like that?
Ta
Roden - Replies:
Radiator Fan and Service TAG Issue
Hi all.
Just had my car serviced today, they said they cannot reset the service notice as it just keeps coming back, and it probably means there is an issue somewhere.
They also said that the radiator fan runs on high constantly. This I had noticed about 4 days before booking it in, it just started.
It came about as I start the car, the fan would kick in and run on low or medium, I thought it odd as it normally would only come on when hot or idling. After about 5 mins of driving the fan s
kmy - Replies:
P0480-00 fan low speed don't work
I have DTC P0480-00 and low speed engine fan don't work.
Fuses 42 and 48 are OK
Relay KR20C is OK
I need electrical diagram for engine fan for more test.
Engine A20DTH with AC
Please, help me.
Weird burning smell and fan on 100%
Hey guys and girls just thought I would post looking for some advice. Got a 2010 Astra j Sri with 35k on the. Lock and recently I've been having a service vehicle soon message pop up more frequently. Tried a mate's code reader but I don't believe it was up to much as it didn't find anything. This coincides with sometimes the engine fan is on 100% at hot and cold start.
Has this happened to anyone else? I get a sort of burning smell in the vents at times also.
Not really even sure where
DaPa - Replies:
Cooling Fan coming on for a few seconds
Recently on two occasions after I have driven the car for a while, stopped and then re start the cooling fan has come on for a few seconds.
Could this be related to the thermostat wiring harness issue they had?
It is a 1.6 Petrol Auto
dp
philg25 - Replies:
Continuuous fan operation
Astra 1.6 J 2013 78000 miles
Warning light came on yesterday regarding engine overheating and guage hit maximum. Called AA and they diagnosed a faulty coolant temperature sensor. Got above part and fitted which sorted the high temperature light but now the fan runs continuously on high. Had this before when my thermostat failed which I replaced about 10000 mile ago. Has another sensor failed and if so which one? Thanks for any help.
Cheers Phil
Opel Astra J interior fan problem
Hei,
I have got some problem with my interior fan and with winter coming it is crucial this little thing work properly.
I will now try to explain this problem:
9/10 times the fan work as it should on step 1-6.
After going on max (step 6) for some time and I want to slow it down it start to lagg, going very uneven and sound bad, even stops working, on every stage down to zero.
If I choose full speed again it get a kick in the butt and work like a star on stage 6.
I put it on the flo
Astra J SRI 13 Plate - Radiator Fan
Good evening guys,
looking to see if anyone can help with a problem i have with my 13 plate Astra J SRI,
For a while the radiator fan was staying on (common issue i know), i didnt do anything about it until recently,
I have replaced the thermostat and housing, the temperature sensor, checked that all the fuses are intact, removed the sensor from the air filter and still nothing from the fan,
I kept getting the message "coolant level low - add Coolant" i replaced the expansion tan
