with screen 950 touch info navi
Navi 950 with touch screen info
The info was originally found via YouTube and https://www.clubgsispain.com/
But once we saw it @Jpbroad1970 & myself got stuck in & started playing.
We can enable touch screen rear camera and DAB+ with a Chevy theme quite nicely.
For this you need a screen with the following part number 22851302
There are 4 extra wires needed for touchscreen as detailed below, The white & blue are shielded with the black being the drain.
Video of touch screen working.
Rusty
Well worth the effort & another good job done for the OEM touchscreen.
I can now confirm that my unit is fitted too. After a few quirks and throwing my dummy out the pram like a petulant child. It's a great piece of kit. Properly modernised the head unit and touch screen is a great addition.
Cameras next then I will get some pics up. Who would have thought a 2011 astra be so modern lol.
Super mod...will this only work with the NAVI950?
Navi950 navi650 and cd600
Hello guys, could you please give more info how you enable the touch?  Is it just VCI for the new screen or you need to flash the Navi with chevrolet firmware which supports touch? If so is it available somewhere for download and is it compatible with everything in Opel/Vauxhall cars?
btw I was trying to reverse engineer the navi 950 firmware to find any traces of AA/CarPlay (so far none found), so this is very interesting topic.
Do you know what is the module that enables AA/CarPlay on the video?
Great...thanks
(1:st-Feb-2021, 11:06:08)moole6 Wrote: Hello guys, could you please give more info how you enable the touch?  Is it just VCI for the new screen or you need to flash the Navi with chevrolet firmware which supports touch? If so is it available somewhere for download and is it compatible with everything in Opel/Vauxhall cars?
The radio needs to be programmed with the calibration files for touch screen.
I had to get a custom VCI code made for mine (NOT BY GM AS GM won't support it) but going down the custom VCI code route it leaves you able to select the following options.
Chevy / Vauxhall or Opel theme (VXR/OPC)
Rear camera with or without guide lines
DAB+ or no DAB+
Infinity sound or standard.
Control type IE Astra, Insignia, Mokka, Zafira or Meriva.
The only thing I found was missing was the option to turn the rear camera on/off within the settings which is being worked on to reenable.
it works with everything on vauxhall Opel.
The 650/950 Never supported AA/carplay I do think they intensions where there for it.
The interface used to add AA/carplay is https://www.navtool.com/buick-verano-201...rplay.aspx
So is this the only way to get Android Auto on the stock headunit/fascia? I have a Navi 950, and my end goal would be to have Android Auto running on it (Not just an Android Headunit)
How much total would be to have the whole solution sourced, fitted (might be able to do these myself) and most importantly programmed?
It is the only way other than android head unit.
Your 950 can be reprogrammed for touch then you need touch screen and a little bit of wiring plus the module.
@rusty2009 is you man for all the programming
  NAVI 900 > NAVI 950 (2013) Lansa 20 20,060 8:th-Dec-2020, 22:34:47
  NAVI 950 DAB+ Upgrade leighton.read@sky.com 10 13,041 11:th-Oct-2020, 09:17:50
  NAVI 600 Lost Navigation Voice. Roden 3 7,092 15:th-May-2020, 20:13:19
Last Post: Roden
  Navi 50 Intellilink marktourino 3 9,109 27:th-Aug-2018, 08:57:26
  How to remove the head unit from the car includes Screen removal Rusty2009 9 30,858 28:th-Sep-2017, 19:00:13
  Navi 900 upgrade. Tylerrattv 4 8,828 4:th-Aug-2017, 06:18:49
Last Post: Tylerrattv
  M072 (S160) Android Head Unit Install/Info sheppy1 654 553,496 21:st-May-2017, 12:55:12
  Updated version of Navi 950 IntelliLink Greg-new 4 14,709 22:nd-Jan-2017, 21:18:42
  Navi 650 john 1 8,323 22:nd-Jul-2016, 21:03:13
  Navi 900 - 3rd Party Software? C0ntax 2 7,603 29:th-May-2016, 11:42:08
12 User(s) read this thread:
AlexFitton (9:th-Mar-2026, 16:31:40), husky (13:th-Mar-2026, 07:15:51), milozic (24:th-Jan-2026, 20:36:34), johnny77 (27:th-Apr-2025, 17:24:35), obsidian (27:th-Aug-2025, 22:06:30), Toffel (2:nd-Jun-2025, 21:45:43), TheGibs (7:th-Aug-2025, 22:43:10), ImaoCow (19:th-Aug-2025, 00:52:03), TonyP (21:st-Mar-2026, 21:20:38), JOPC (20:th-Jan-2026, 22:19:40), ionutalexandru (29:th-Jan-2026, 16:07:37), lar77 (18:th-Feb-2026, 12:02:37)
