900 upgrade navi
Navi 900 upgrade.
i want to upgrade m Navi900 unit to some after market unit, i want to keep it as stock as possible so steering wheel controls and centre buttons working and the climate controls on the screen.  i've read that the wiring is different for navi900 modules.
I'm quite confident if i need to make changes to wiring ect but want to make sure its easy to revert back to stock.
thanks
Moving the pins around is very easy.
Steering wheel buttons will remain to function.
Control panel needs to be swapped for a CD400 one.
Armrest control functionality will be lost.
I am currently building a module that remedies the latter 2.
(3:rd-Aug-2017, 09:29:42)zzattack Wrote: Moving the pins around is very easy.
I'm waiting on siggy coming into my local scrapyard so I can get the armrest control out with some loom want to see if I can get it working on my Astra.
I don't think the armrest control is very different from the regular panel.
I got most of the signal codes from the CD400 panel now (the GMLAN ones).
Next will be getting the codes from the CD500/DVD800 panel (the LINbus ones).
The armrest controls will also be LINbus, so when I'm able to extract the DVD800 codes it'll be no problem to also get them from the armrest controlle.r
When done, I'll just connect the DVD800 panel and armrest directly to my gateway which will then translate the LINbus inputs to equivalent GMLAN outputs.
is it possible to link me to a guide on what pins need swapping?
thanks
  Navi 950 with touch screen info Rusty2009 9 15,121 25:th-Feb-2021, 13:59:32
  NAVI 900 > NAVI 950 (2013) Lansa 20 20,819 8:th-Dec-2020, 22:34:47
  NAVI 950 DAB+ Upgrade leighton.read@sky.com 10 13,359 11:th-Oct-2020, 09:17:50
  NAVI 600 Lost Navigation Voice. Roden 3 7,322 15:th-May-2020, 20:13:19
Last Post: Roden
  CD400 upgrade Astra vxr 2014 Nathan 6 9,127 22:nd-Oct-2019, 20:13:14
  Astra SRi CDTI VX Line - CD400 Upgrade options AdaKer 3 7,456 13:th-Aug-2019, 06:48:28
Last Post: Schiffers
  Navi 50 Intellilink marktourino 3 9,240 27:th-Aug-2018, 08:57:26
  Updated version of Navi 950 IntelliLink Greg-new 4 15,022 22:nd-Jan-2017, 21:18:42
  CD400 upgrade/touchscreen Olly-Midd 20 26,804 15:th-Aug-2016, 15:18:56
  Navi 650 john 1 8,439 22:nd-Jul-2016, 21:03:13
Happy25 (15:th-Jun-2025, 19:45:05)
