How to remove the head unit from the car includes Screen removal
How to remove the head unit from the car.
Includes Screen removal.
Tools needed
* Cross head screw driver
* 7mm socket
*Small slot head screw driver or paper scraper.
Here's how it look to start.
[Image: https://www.vxoc.org.uk/Images/rusty/pos...dio/00.jpg]
1. Remove the non-slip mat.
[img]https://
Pc Screen recorder
I've finally found a nice screen recorder which work very well and gives nice clear videos,
it's also freeware http://srecorder.com/
Videos are nice and small but you can make them smaller using windows movie maker and there is no loss of quality.
Navi screen protector
Has anyone with factory navi used a screen protector?
There are loads on eBay like the one below.
https://www.ebay.co.uk/itm/361545385323
Multi function display screen
Hi there. Does anyone have a 13 plate Astra j vxr multi function display for sale. I only need the trim and it's for the older LCD one many thanks in advance
M072 Glass Screen Protector
Hey chaps
Has anyone bothered to put a glass protector on their M072 unit? If so which did you use? I'd like to get one for mine
Android 9.7" vertical screen
After analyzing the various alternatives to replace the CD400 of my 1.7 CTDI 2011 for an android I opted for this model https://es.aliexpress.com/item/10-4-tesl...63c0xAeGkc
It arrived at 15 days in perfect packaging.
Aided by the how to of the forum the assembly was not complicated at all, although it takes 3-4 hours if you have prepared it well, but it can be double.
The truth i
ECO Button tesla style screen
Hello! My tesla style screen arrived today and i plan to connect it over the weekend, the problem is it doesn't have an ECO button..i watched a video on youtube of a Russian guy wiring it to the Parktronics button(my Astra doesn't have that) and i am planning to do the same. But just to be sure where to connect the blue and where the black wire does anyone know the pin layout on the original Parktronics plug?
Navi 650 Screen Surround Part Number
As per the title really, does anyone know what the part number for a navi 650 screen surround is?
Would a surround with part number 13368988 fit?
Navi 950 with touch screen info
[align=center]The info was originally found via YouTube and https://www.clubgsispain.com/
But once we saw it @Jpbroad1970 & myself got stuck in & started playing.
We can enable touch screen rear camera and DAB+ with a Chevy theme quite nicely.
For this you need a screen with the following part number 22851302
There are 4 extra wires needed for touchscreen as detailed below, The white & blue are shielded with
Navi 650 to Tesla Style Touch Screen
Good Afternoon,
I was wondering if anyone has added the tesla like touch screen to an Astra J that originally had a navi 650 in, is it as simple as plug and play, or will the loom require modification?
All the best,
Josh
