discs and pads replacement
Replacement discs and pads
Firstly, great forum with loads of useful info.
I need to replace the front discs and pads on my 2.0 CDTi. Eurocarparts list a few brands to choose from, one of which is Brembo. Is it worth upgrading to Brembo discs and pads with standard calipers? The price difference isn't much so I'm tempted but I don't know if braking or longevity will be improved - does anybody have any advice/experience?
Thanks in advance.
I fitted EBC dimppled and grooved all round with yellow stuff pads.
Breaking is abit better but I did it for looks over anything else.
I’m trying to replace the rear pads on my Astra J but have hit a snag. Replacement of the front pads was nice and straightforward but the problem I’m having with the rear is that the bolt head on the mass displacement damper stud is worn and using a spanner on it is going to round it off. The studs on both sides are the same and a spanner will not grip them. Has anyone had a similar problem and if so how do you get them out?!
Many thanks
(23:rd-May-2018, 17:27:04)Petrolhed917 Wrote: Hi,
Many thanks
Mole grips.
  GTC Horn Replacement ed-b 1 3,426 12:th-Jul-2021, 08:53:37
  Battery replacement - AGM or regular everson38 1 3,863 22:nd-Jun-2021, 10:37:05
Last Post: MarkAP68
  Glow plug replacement - Things to consider everson38 13 14,578 20:th-Jun-2021, 17:44:37
Last Post: everson38
  front brake discs bgb65uk 4 5,277 23:rd-Jul-2020, 10:56:25
  Changing rear brake discs Big Dave2 3 5,396 26:th-Jun-2020, 18:54:19
  Changed Brake Pads, now feels like fronts are sticking Vx-Mad-G 5 11,532 25:th-Jul-2018, 15:44:04
Last Post: Vx-Mad-G
  Flexride shock absorber replacement rlievens 3 7,280 28:th-Feb-2018, 08:25:21
Last Post: rlievens
  Changing rear pads richje100 8 10,086 12:th-Jun-2017, 13:18:52
Last Post: Astra VXD
  GTC 2.0 cdti front pads tatters40 1 7,028 7:th-Mar-2016, 22:04:02
Last Post: irmartyn
  Break Replacement sheppy1 15 19,760 17:th-May-2015, 21:40:02
cpeter53 (19:th-May-2025, 12:58:32)
