amp settings fluids lubricants wrench engines torque petrol
Lubricants, Fluids & Torque wrench settings Petrol Engines
Lubricants & Fluids and Torque wrench settings Petrol Engines
Engine Oil
Capacity including Oil filter
[TR]
[TD]1.4 Engines[/TD]
[TD]4.0 L[/TD]
[/TR]
[TR]
[TD]1.6 Engines[/TD]
[TD]4.5 L[/TD]
[/TR]
[TR]
[TD]Difference between Min & Max on Dipstick[/TD]
[TD]1.0 L[/TD]
[/TR]
Cooling System
Cooling System
[TR]
[TD]6.2 L[/TD]
[/TR]
[TR]
[TD]5.9 L[/TD]
[/TR]
Antifreeze Mixture
Antifreeze Mixture
[TR]
[TD]50% antifreeze[/TD]
[TD]Protection down to -40ºc[/TD]
[/TR]
Transmission
Manual transmission
Manual transmission
[TR]
[TD]5-Speed[/TD]
[TD]1.6 L[/TD]
[/TR]
[TR]
[TD]6-Speed[/TD]
[TD]1.3 L[/TD]
[/TR]
Automatic transmission (at fluid change) 4.0 to 6.0 Litres
Fuel tank
Fuel tank
[TR]
[TD]56 L[/TD]
[/TR]
Ignition system
Spark plugs
Spark plugs
[TR]
[TD]Normally Aspirated engines[/TD]
[TD]Champion RC 10MCC R6[/TD]
[/TR]
[TR]
[TD]1.4 Turbo[/TD]
[TD]NGK IFR7X-7G[/TD]
[/TR]
[TR]
[TD]1.6 Turbo[/TD]
[TD]NGK ZFR6BP-G[/TD]
[/TR]
[TR]
[TD]Electrode gap[/TD]
[TD]0.85 to 0.95 mm[/TD]
[/TR]
Brakes
Brakes
[TR]
[TD]Minimum fraction material[/TD]
[TD]2.0 mm[/TD]
[/TR]
Torque Wrench Settings
[TR]
[TD][/TD]
[TD]Nm[/TD]
[TD]lbf ft[/TD]
[/TR]
[TR]
[TD]Oil Filter housing cap to filter housing[/TD]
[TD]25[/TD]
[TD]18[/TD]
[/TR]
[TR]
[TD]Road-wheel nuts[/TD]
[TD]140[/TD]
[TD]103[/TD]
[/TR]
[TR]
[TD]Spark plugs[/TD]
[TD]25[/TD]
[TD]18[/TD]
[/TR]
[TR]
[TD]Sump drain plug[/TD]
[TD]14[/TD]
[TD]10[/TD]
[/TR]
thanks rusty i needed the coolant capacity
  Glow Plug Torque specs everson38 1 4,546 18:th-Jun-2021, 20:18:21
  Lubricants, Fluids & Torque wrench settings Diesel Engines Rusty2009 2 18,346 31:st-Aug-2020, 02:21:26
Last Post: M222RJF
Engines Techincal Data (First Post) Rocky33 6 13,305 29:th-Jan-2019, 21:08:04
Last Post: Rocky33
  Wrench - CH 49375??? Steveb19111978 3 6,118 17:th-Oct-2018, 12:30:20
