Lubricants, Fluids & Torque wrench settings Petrol Engines
Lubricants & Fluids and Torque wrench settings Petrol Engines
Engine Oil
Capacity including Oil filter
[TR]
[TD]1.4 Engines[/TD]
[TD]4.0 L[/TD]
[/TR]
[TR]
[TD]1.6 Engines[/TD]
[TD]4.5 L[/TD]
[/TR]
[TR]
[TD]Difference between Min & Max on Dipstick[/TD]
[TD]1.0 L[/TD]
[/TR]
[b]Cooling System[/
Lubricants, Fluids & Torque wrench settings Diesel Engines
Lubricants & Fluids and Torque wrench settings Diesel Engines
Engine Oil
[TABLE=Capacity Inc Oil Filter]
[TR]
[TD]1.3 Engines[/TD]
[TD]3.5 L[/TD]
[/TR]
[TR]
[TD]??[/TD]
[/TR]
[TR]
[TD]1.7 Engines[/TD]
[TD]5.4 L[/TD]
[/TR]
[TR]
[TD]2.0 Engines[/TD]
[TD]4.5 L[/TD]
[/TR]
[TR]
[TD]Differen
Torque APP Error codes
does anyone know what 'fuel system monitor bank 1 min 10,432minute max 40,992minute current 6,624 minute' means???
Torque setting info
What is the recommended torque setting for the 2 suspension mounting bolts? The ones that connect the hub to the suspension. Thanks
M072/ Bluetooth/Torque issue
I am in the process of recommissioning my Astra J and decided to try out my OBD2 bluetooth unit with my M072 headunit to see how well it works.
The problem I have is that on first fitment it saw the OBD unit but couldn't connect (wirelessly via bluetooth), then after decided it couldn't see it at all.
The unit works fine with the Torque lite app on my android phone when used in my Volvo so I'm at a loss as to why it won't work with the same app on my android HU in the J.
Is there a setting
Glow Plug Torque specs
Hey guys,
I have a 62plate 1.7 Astra GTC j.
Does anyone know what the torque specs are in Nm for the glow plugs? I've read a few things but getting conflicting results.
