diesel amp settings fluids lubricants wrench engines torque
Lubricants, Fluids & Torque wrench settings Diesel Engines
Lubricants & Fluids and Torque wrench settings Diesel Engines
Engine Oil
Capacity including Oil filter
Capacity Inc Oil Filter
[TR]
[TD]1.3 Engines[/TD]
[TD]3.5 L[/TD]
[/TR]
[TR]
[TD]1.6 Engines[/TD]
[TD]??[/TD]
[/TR]
[TR]
[TD]1.7 Engines[/TD]
[TD]5.4 L[/TD]
[/TR]
[TR]
[TD]2.0 Engines[/TD]
[TD]4.5 L[/TD]
[/TR]
[TR]
[TD]Difference between Min & Max on Dipstick[/TD]
[TD]1.0 L[/TD]
[/TR]
Cooling System
Cooling System
[TR]
[TD]6.6 L[/TD]
[/TR]
[TR]
[TD]??[/TD]
[/TR]
[TR]
[TD]7.1 L[/TD]
[/TR]
[TR]
[TD]6.9 L[/TD]
[/TR]
Antifreeze Mixture
Antifreeze Mix
[TR]
[TD]50% antifreeze[/TD]
[TD]Protection down to -40ºc[/TD]
[/TR]
Transmission
Manual transmission
Manual Trans
[TR]
[TD]5-Speed[/TD]
[TD]1.6 L[/TD]
[/TR]
[TR]
[TD]6-Speed (M32)[/TD]
[TD]1.3 L[/TD]
[/TR]
[TR]
[TD]6-Speed (F40)[/TD]
[TD]1.5 L[/TD]
[/TR]
Automatic transmission (at fluid change) 3.0 Litres (Approximately)
Fuel tank
Fuel Tank
[TR]
[TD]All Except 1.3 L With Stop-Start system[/TD]
[TD]56 L[/TD]
[/TR]
[TR]
[TD]1.3 L with Stop-Start system[/TD]
[TD]46 L[/TD]
[/TR]
Brakes
Brakes
[TR]
[TD]Minimum fraction material[/TD]
[TD]2.0 mm[/TD]
[/TR]
Torque Wrench Settings
[TR]
[TD][/TD]
[TD]Nm[/TD]
[TD]lbf ft[/TD]
[/TR]
[TR]
[TD]Oil Filter housing cap to filter housing[/TD]
[TD]25[/TD]
[TD]18[/TD]
[/TR]
[TR]
[TD]Road-wheel nuts[/TD]
[TD]140[/TD]
[TD]103[/TD]
[/TR]
[TR]
[TD]Fuel Filter base[/TD]
[TD]25[/TD]
[TD]18[/TD]
[/TR]
[TR]
[TD]Sump drain plug[/TD]
[TD]20[/TD]
[TD]15[/TD]
[/TR]
any update on the petrol engine oil and coolant capacity ??
just seen this is for diesel thanks i found it
cheers Rusty2009
  Glow Plug Torque specs everson38 1 4,439 18:th-Jun-2021, 20:18:21
  diesel mileage badger64 21 16,337 29:th-Jun-2020, 23:12:00
Engines Techincal Data (First Post) Rocky33 6 13,152 29:th-Jan-2019, 21:08:04
Last Post: Rocky33
  Wrench - CH 49375??? Steveb19111978 3 5,983 17:th-Oct-2018, 12:30:20
  Lubricants, Fluids & Torque wrench settings Petrol Engines Rusty2009 1 19,706 17:th-Feb-2015, 02:54:00
Rusty2009 (11:th-May-2025, 18:38:40), lollone (31:st-Oct-2025, 16:52:13)
