remote locking coolant engine and
Engine Coolant and remote locking
I bought my car about 6 months ago, its only 5 years old and had less than 40k on the clock. At first I had two issues with the car, the engine coolant light was coming on even though it had just been serviced and remote locking with the buttons in the car was hit and miss, sometimes they'd work other times it wouldnt, same with taking the key out, it wouldn't automatically unlock the doors at times.
I took it back to lookers and they spent around 3 weeks in total with the car (locking was meant to be fixed first time and wasn't.) I just recently topped up the coolant as it needed topping up however it's still warning me now 1/2 times every journey I make. The remote locking seemed to be fixed for a few months but the past 2 months it's been that bad that I've had to just get in and use the lock on the key to lock and unlock the doors.
I was wondering if this is common or not and how to try and fix these issues
Regarding the key, if you've got a spare one, try using that for a while to see if the fault reoccurs.
Process of elimination and all that.
Is the car still losing coolant, or are you just getting the low level message?
If the latter, it could be the sensor in the tank.
If the former, then it needs a pressure test, and also a sniff test of the coolant carrying out to determine where the leak is, or if it's pending head gasket failure.
  1.7 cdti engine judder in 5th and 6th ScottN2211 0 3,319 21:st-Oct-2023, 16:27:48
Last Post: ScottN2211
Photo Bleeding coolant liquid pipe kebagwan 3 5,303 22:nd-Sep-2019, 07:04:31
  engine problems tucpal 8 17,685 11:th-Jan-2018, 16:13:15
Last Post: kebibg
  Engine sound Lukedent1234 0 5,310 18:th-Sep-2017, 09:26:28
Last Post: Lukedent1234
  GTC Coolant temp sensor chris_yorks 2 7,306 11:th-Jul-2017, 07:38:42
  Black filter/cap under coolant cap won't budge ellis0896 7 10,938 18:th-Jan-2017, 20:32:15
  coolant issue Shorty S91 5 9,189 8:th-Jan-2017, 22:51:27
Last Post: stigeye
  Noise from engine SI SRI 8 16,169 26:th-Nov-2015, 15:17:23
Last Post: monty2000
  Engine sounds funny...... Or not dutton84 15 15,503 11:th-Sep-2015, 09:04:59
Last Post: dutton84
  Astra J 1.7 engine chirping and pressure Jasoncourt 13 21,801 11:th-Sep-2015, 07:25:07
