funny sounds engine not or
Engine sounds funny...... Or not
https://vimeo.com/126470389
Engine seems to have a weird clicking sound. Is that normal?
What car do you have? Is that a corsa?
No. An Astra 1.6
My Astra 1.7 CDTi has a very similar sound. I know the old corsa c used to sound like that when the cam chains were loose. But on my Astra it sounds like something around the injectors,
Oh right. That's bad then from what I've just quickly read on Google. Ha. Is it a timing belt or chain? I assume it's a chain if it rattles
Need to have another listen that was 4 months ago
I don't like diagnosis on video and forums are not the best to get advice take it too a garage it may be something it may be nothing
Sounds like a drev if so unless it's a 1.3CDTI then it will be a belt.
I can't really hear anything wrong but as Paul said best to get a garage to look at it if you think something doesn't sound right.
alternator belt and water pump would be a good guess
what is your milage
54k. Had the fan belt done a month after having the car. That's the screeching one.
This was 4 months ago. Need to have another listen. Because if it is any of the above I need to get it in before the warranty runs out
was the water pump done at all
i would take it in just to be safe
That noise is not the water pump.
It sounds like injector tick but it's certainly not ancillary related. It's something on the top of the engine, I don't know if they're chain driven or not but certainly get it looked at.
Do you find that if you rev it, it gets quicker with revs the whole way up or does it stop after a certain revs?
I find in general is kind of sluggish. Ha. But never driven another on so nothing to compare to really
But yeah at low revs it's seems slow. Have to really rev it. Not sure if that's just what Astras are like though
Just had a quick look online and the cam belt should last 10 years or 100,000
Some say it's a cam chain
If it's got a metal cover its a chain and if it's got a plastic cover its a belt
6yrs or 100,000 miles I wouldn't leave it that long tho as its rubber
Just checked my Astra out and my injectors tick very loudly too. I'll get a recording for you, but it have a chirping noise that's very loud that u will have to ignore lol
Maybe it is just injector tick then like Jj0063 said
Thanks for looking mate. Gonna have a look again this evening
  1.7 cdti engine judder in 5th and 6th ScottN2211 0 3,352 21:st-Oct-2023, 16:27:48
Last Post: ScottN2211
  Engine Coolant and remote locking dm1996 1 5,865 14:th-Nov-2018, 10:19:53
  engine problems tucpal 8 17,739 11:th-Jan-2018, 16:13:15
Last Post: kebibg
  Engine sound Lukedent1234 0 5,326 18:th-Sep-2017, 09:26:28
Last Post: Lukedent1234
  Noise from engine SI SRI 8 16,269 26:th-Nov-2015, 15:17:23
Last Post: monty2000
  Astra J 1.7 engine chirping and pressure Jasoncourt 13 21,967 11:th-Sep-2015, 07:25:07
  Engine Rattling sheppy1 39 45,142 16:th-May-2015, 09:47:27
  Funny noise from suspension Cameron UK 5 10,649 14:th-May-2014, 08:26:02
Last Post: cornishtaz
