in judder cdti 6th 7 engine and 1 5th
1.7 cdti engine judder in 5th and 6th
My 2011 astra j 1.7 cdti is juddering when accelerating from 1500rpm to 2000rpm in 5th and 6th (worse in 6th) no juddering above 2000rpm or when just cruising, only happens when you try and give it some gas. Changed MAF sensor, fuel filter, air filter and suction control valve. Cleaned EGR valve and MAP sensor, also had front wheels balanced, still no joy. Anyone had it before or got any ideas?
  Astra J 1.6 CDTi increased fuel consumption _Mita 2 11,947 1:st-Mar-2020, 22:27:38
Last Post: _Mita
  Astra ST 1,6 CDTi, error code P0181 claymansvk 1 5,919 20:th-Feb-2020, 19:32:31
  Engine Coolant and remote locking dm1996 1 5,865 14:th-Nov-2018, 10:19:53
  Astra J 2.0 cdti noise on cold start up Iaintruten 3 10,798 17:th-Jan-2018, 17:26:31
Last Post: Iaintruten
  engine problems tucpal 8 17,739 11:th-Jan-2018, 16:13:15
Last Post: kebibg
  Engine sound Lukedent1234 0 5,326 18:th-Sep-2017, 09:26:28
Last Post: Lukedent1234
  Noise from engine SI SRI 8 16,269 26:th-Nov-2015, 15:17:23
Last Post: monty2000
  Engine sounds funny...... Or not dutton84 15 15,639 11:th-Sep-2015, 09:04:59
Last Post: dutton84
  Astra J 1.7 engine chirping and pressure Jasoncourt 13 21,967 11:th-Sep-2015, 07:25:07
  Engine Rattling sheppy1 39 45,142 16:th-May-2015, 09:47:27
