clutch clicking
Clicking clutch
Every time I decompress the clutch, it makes a noticeable clicking sound as if it's metal on metal. You can feel in as you press it and hear it too. It happens just at the start of the decompression too.
Anyone know if a bit of grease will sort it or is it an underlying thing that a mechanic needs to look at?
yes grease will sort it out very common problem
use some bearing grease and apply by hand get it on the spring
hard to get to but you will see what i mean when you get your hand up there
I've seen the piston with grease on, is it next to that?
I'm trying to look on Halfords but it only has multi purpose grease @Tucpal
try this mate
http://www.halfords.com/motoring/engine-...rease-500g
Cheers mate, I'm popping in today, the other half is buying me a dashcam for my birthday
cool add some nice pics etc of that
here you go there is a thread on this here
https://www.vxoc.org.uk/forum/Thread-squ...tch-peddle
Mate it's not a squeak, it's a clicking noise like metal on metal
press the clutch pedal if it make a clicking or squeak that will be the problem
Bought some today, I can't apply it just yet, bit busy
@Tucpal I applied some of that grease and it hasn't worked. I couldn't see the spring you were referring to, I even stuck my hand all the way and couldn't feel it. I did see the piston that it pushes so I applied it to that but it's still not done anything, any suggestions?
Update: the car went to the garage for its heated seat replacement and I mentioned the clutch pedal. They've just rang me, mentioned they've tried everything with the spring and it couldn't be fixed so now I need a new clutch pedal apparently. @Tucpal
and are they paying it maybe your spring had broke
Bests the usual "sorry we can't find a fault"'
  AC Compressor clutch broken rlievens 2 4,240 19:th-Sep-2020, 19:01:39
  Clicking noise THOMAS123 1 4,781 16:th-May-2018, 08:06:00
Last Post: rlievens
  Can't get in gear - clutch problem? klargon 0 5,119 9:th-Dec-2017, 16:21:11
Last Post: klargon
  Clutch adjustment/grinding gears dammfust 1 5,406 22:nd-Sep-2017, 00:03:22
Last Post: mw2299
  Astra J Clutch pedal loose abba34 6 12,956 16:th-Sep-2017, 00:11:26
Last Post: slavenK
  Astra Gtc 1.4t clutch problem Wayneofwolves 2 6,738 25:th-Feb-2017, 09:16:33
Last Post: Wayneofwolves
Question Strange Clicking Noise Astra J? jsmith83 2 6,791 31:st-Dec-2016, 17:41:54
Last Post: jsmith83
  Astra 1.6 clutch judder after being stuck in traffic tina r 3 12,130 6:th-Aug-2016, 23:13:10
Last Post: marcus
