problem high brake level
High Level Brake Problem
Anyone else had problems with the high level brake light mine seem to have stopped working? Any ideas how to try and solve it or is it a new light unit?
Had the same problem with mine. It's a new unit. Mine was done under warranty.
I'll try and get in touch with vx but I think my warranty is out unfortunately will be cost of replacement part.
Does anyone know the part number?
It's about £28 Iirc from Autovaux will look the part number up tomorrow.
Mine went then wiggled wire & hey presto
Is there a how to? Just I don't fancy messing around with electrics.
13262019 LAMP, ASSY., HIGH-LEVEL BRAKE LAMP (NLS.- USE 13372164)
Thanks bud
  Brake pedal sensor learn. Richiew1986 0 3,013 22:nd-Jul-2021, 16:53:31
Last Post: Richiew1986
Sad Astra 1.7 CDTI fuel quality problem klajdi 0 4,277 10:th-Sep-2020, 12:10:05
Last Post: klajdi
  DPF Level App bannan 6 6,959 17:th-May-2020, 11:11:16
Last Post: Kiel0777
  Gtc 2017 1.4t 120 front brake disc size Nathan191210 2 8,351 25:th-Apr-2020, 07:41:05
  Injectors or SCV problem? kartush45 1 4,955 11:th-Mar-2020, 11:08:58
  High Idle 1.7 cdti Cossie 0 4,486 26:th-Aug-2019, 07:06:32
Last Post: Cossie
  Rear brake pads and discs everson38 4 6,972 28:th-May-2019, 10:53:57
  Electric Window intermittent problem Stanhope 3 7,646 21:st-Mar-2019, 14:35:49
Last Post: Stanhope
  Astra J self starting problem Jopo2311 8 8,853 16:th-Mar-2019, 10:29:33
  Jolt when releasing brake on autobox Djones55 3 7,432 21:st-Oct-2018, 10:42:34
Last Post: Canasta
