to rattles j area passenger side astra trim interior from how stop
How to stop Interior Trim Rattles from Passenger side area Astra J.
[Image: 9nd4_zpsea5fce57.jpg]
This How to will Stop Rattles that Appear to be Coming from the Seat Belt or A Pillar Area.
For a while now i have a Wired Rattle that seems to come from the Passenger Side Area
Around the Seat Belt or A Pillar Area and i have not been Able to Put my Finger on were Exactly it has been Coming From
[Image: trim%20sp%20006_zpsbagskczt.jpg]
I Noticed if i Pushed Down on the Console in the Headliner This would Stop
So i came up with a Very Simple Solution that works.
The Rattle is a Vibration Rattle Due to a Foam Block in the Console in the Headliner not being as Tight a Fit as it Should
This makes the Sound Travel and makes it Hard to Pin Point were it is Coming From
So a very Simple Solution was call For and it Works.
Remove the Trim with the Two Vents from the Console in the Headliner
and inside at the Back you will see a Foam Block Simply Push a Sponge in between
the Block and the Roof this will Stop the Vibration Rattle that Travels to the Seat Belt Area.
[Image: trim%20sp%20001_zpsu0k1aqjr.jpg]
[Image: trim%20sp%20002_zpsthltenxp.jpg]
[Image: trim%20sp%20003_zpswrkmswir.jpg]
[Image: trim%20sp%20004_zpsloqrx6ty.jpg]
[Image: trim%20sp%20005_zpsevkgplra.jpg]
This will also Stop Any Rattles you may have from the Console Itself also
Some have Suggested Adding Sticky Tads to the Trim but this Works just as Good Also
a Very Simple Solution But this Really has Worked.
Nice one mate I do get a squeaking noise from the passenger seat belt when it's in use Just haven't be ****d to look into.
its a strange fix but it works
I think this may be the same issue I'm seeing!! Took me ages to pin point it as I only heard it at high speeds on gravel style roads. I noticed that smacking the roof console area did make it go away for a while so must be the issue you mention...will give this a go Smile thanks
If it works let me know
Will do mate! Smile haven't heard it for a few days though..have a new one which seems to either be coming from the passenger seat or somewhere in the rear :-/ lol
I used blu tac on mine a while back, think I seen it suggested in here. Out of a few rattles/vibrations this was the loudest. So glad it's fixed, real annoying
Yeah I have an annoying rattle which almost sounds like metal on metal coming from the NSR somewhere. Doesn't do it all the time however.
I have also been getting this intermittently so whilst I was putting my USB sockets in today I placed a sponge up there, if this solves that I will be forever grateful!
hope so mate
  Driver-side cubbyhole catch JonathanLondon 2 5,159 9:th-Sep-2021, 11:45:38
Last Post: JonathanLondon
  Vauxhall Astra 1.7 CDTi SRi no phone settings, why!? Ashleigh96x 6 20,889 31:st-Mar-2021, 09:49:11
Last Post: HB Car
  How to stop Smelly air-con grahamfromoldham 18 26,679 31:st-May-2020, 23:58:19
Last Post: moxol
  HOW TO FIX HEATED SEAT AND REPLACE SEAT COVER ASTRA J tucpal 78 125,021 13:th-Nov-2019, 09:49:21
  HOW TO FIT A PEDAL BOX, ASTRA J. tucpal 24 41,167 30:th-Jul-2019, 17:01:36
Last Post: param84
  Swap astra J dash display chrisscruton 6 13,744 25:th-Mar-2019, 10:16:12
Last Post: chrisscruton
Photo help with interior A trim removal passenger pillar astra j stestrange82 3 13,534 20:th-Feb-2019, 13:45:22
  How to remove air vent trim Rusty2009 10 28,616 25:th-Aug-2018, 14:20:50
Last Post: mikeb7900
  How to, Door Lock Catch Covers. Astra J. tucpal 10 17,997 28:th-Jun-2017, 12:58:56
Photo Astra vs. GTC Interior question neilll 2 9,730 20:th-Apr-2017, 21:11:00
Last Post: neilll
