» Members: 12,339
» Latest member: Henhead78
» Forum threads: 4,564
» Forum posts: 49,695
Clean DPF - O2 sensor loc...
41 minutes ago
  Retrofit Rear Power point 5 door Astra J
Posted by: Ballinlea - 14:th-Mar-2019, 23:24:47 - Forum: Retrofit How-to's - Replies (3)
Has anyone retrofitted a 12v power point to a 5 door Astra J which has an armrest? There is no cable for it and nothing tucked away. I have had a good look round the front power point.
  1.3 cdti mk6
Posted by: Poejayne - 12:th-Mar-2019, 20:18:07 - Forum: Mechanical - Replies (1)
I’m getting my Astra re mapped but want to put an induction kit on it can anyone please help me as I don’t know which ones will fit can I put any induction kit on it or do I need a specific one? And if anyone knows of any performance upgrades that I could do on the 1.3 engines, thank you
  tank replacement and still refill tank error
Posted by: alexy357 - 11:th-Mar-2019, 23:25:26 - Forum: Astra-J/GTC Common Problems - Replies (5)
hey guys,
i changed coolant tank because mine leaked. everything was fine i replaced it and refill.
the level is to max. but i still have an error message on dashboard "level low please refill" i don't understand what is the problem..
  Projector headlamps needed
Posted by: defrank - 11:th-Mar-2019, 21:03:12 - Forum: Wanted - Replies (5)
Hello all. I really need projector headlamps for the Astra J 5 door facelift model. Any assistance would be much appreciated.
Thank you.
  Front suspension knock?????
Posted by: Sri~mike - 11:th-Mar-2019, 20:27:56 - Forum: Astra-J/GTC - Replies (10)
Hey guys, I’ve recently noticed that driving over uneven/ rough roads that I’m getting a knocking noise, if I hit a pothole or large bump there’s nothing but any sort of slight bumps or similar and I’m getting lots of knocks like the anti roll bar bushes are shot, last weekend I got it on my mates 2 poster ramp and got the pry bar out checking everything and it’s all completely solid, but for how cheap they were I fitted a pair of new drop links thinking it could only be them but no joy, all my shockers are clean and bone dry and springs are perfect and I lowered the car so the tyres were about an inch off the ground and put a long pry bar under each wheel to check the top mounts and no play whatsoever, please help???? Oh also it’s a 1.4 Sri on a 65 plate with 40k miles thanks
  radio code
Posted by: marky79 - 9:th-Mar-2019, 21:21:17 - Forum: Site updates - Replies (6)
if I take the battery off will I need a code for the radio.
  Car Ramps?
Posted by: fezza37 - 9:th-Mar-2019, 20:09:20 - Forum: Astra-J/GTC - Replies (3)
I've bought these ramps from Halfords to do a job on my Misses Corsa D, they say they are for cars withe tyres up to 185mm but they are actually 240mm wide, my car Astra J 2CDTI has 19" 235's on,
would you chance it?
Halfords 2 Tonne Car Ramp
The Halfords 2 Tonne Car Ramps is designed for tyres with widths from 135mm to 185mm.
[Halfords 2 Tonne Car Ramp Extra Info
  • Height 20cm2 Tonne per pair (1 Tonne per ramp)Suitable for tyres from 135 to 185mm.
  led`s
Posted by: marky79 - 9:th-Mar-2019, 17:45:44 - Forum: Lighting - Replies (1)
can any one tell if the same led`s used in the ipc are the one`s in the steering wheel controls.
  bluetooth
Posted by: marky79 - 9:th-Mar-2019, 17:42:40 - Forum: Astra-J/GTC - Replies (1)
hi all, can any one help me with a bit of info.
I have bought the wife a insignia 09 plate 2.0 cdti sri nav but it don't have Bluetooth.
so can I buy the module and fit it, would it be a case of plug and play and would the cables and plugs be there and would I need
to have it programmed to the ecu.
and where about in the car does it fit.
  carpass code
Posted by: desmo - 9:th-Mar-2019, 01:20:39 - Forum: Astra-J/GTC Technical - Replies (2)
Hi all. just wandering if there is any way of reading my carpass code or am i going to have to purchase from dealer, got my first astra j 3 weeks ago but no pass code,  thanks
