tank refill and error still replacement
tank replacement and still refill tank error
hey guys,
i changed coolant tank because mine leaked. everything was fine i replaced it and refill.
the level is to max. but i still have an error message on dashboard "level low please refill" i don't understand what is the problem..
Did the new tank have the level sensor in it?
(12:th-Mar-2019, 05:12:34)Rusty2009 Wrote: Did the new tank have the level sensor in it?
yes, and before you ask i connected it
https://www.oscaro.com/vase-dexpansion-l...0381-397-p# (i have the same tank, same brand)
i really don't want to put the old sensor to test :
note : ive installed a subwoofer same day so i disconnected the battery + and - during 1 hour .  i have also error message "parking sensor service" ( all sensors working)  and "change oil" (i changed oil at 94000klm on june 18 now im 101000klm,  think its too early no ?"  these message could come because battery was disconnected for long time?
It could be the sensor on the tank or it could be a wire issue, but if the old sensor worked then I would most likely say it's the new sensor at fault.
Parking sensor issue would need to be plugged on to find out what the error is.
As to the oil it's all worked out over how many miles your driving style etc I've never seen it pop-up just because the battery is off & I've had cars in with the battery off for the weekend with no issues. you can always reset the oil life if you wanted to.
(14:th-Mar-2019, 08:44:52)Rusty2009 Wrote: It could be the sensor on the tank or it could be a wire issue, but if the old sensor worked then I would most likely say it's the new sensor at fault.
thanks for your answer rusty.
- for tank sensor i will install the old one this weekend i'll see problem is solved.
-for parking sensor error message is gone so its ok for that.
- for the oil im just surprised to change it after 4000miles and 10 months but it's like that i'll do
  Astra GTC auto gear knob replacement Jayrich872001 12 31,183 22:nd-Jul-2020, 12:21:46
Last Post: DC23
  Astra ST 1,6 CDTi, error code P0181 claymansvk 1 5,651 20:th-Feb-2020, 19:32:31
  Error code B1405 zydreaa 1 8,609 22:nd-Jan-2019, 08:50:49
  sometimes P2598 error appears, egr? Saxito@Tech 0 6,748 17:th-Apr-2017, 11:27:21
Last Post: Saxito@Tech
