ramps? car
Car Ramps?
I've bought these ramps from Halfords to do a job on my Misses Corsa D, they say they are for cars withe tyres up to 185mm but they are actually 240mm wide, my car Astra J 2CDTI has 19" 235's on,
would you chance it?
Halfords 2 Tonne Car Ramp
The Halfords 2 Tonne Car Ramps is designed for tyres with widths from 135mm to 185mm.
[Halfords 2 Tonne Car Ramp Extra Info
  • Height 20cm2 Tonne per pair (1 Tonne per ramp)Suitable for tyres from 135 to 185mm.
[quote='fezza37' pid='50807' dateline='1552158560']
Edit, would you risk using them with an Astra J with 235" wheels at a later date, i still need to use the them for the Corsa
The ramps I have are slightly too small for the tyre I still use them just make sure I centre myself on them properly, granted I don't do anything major with them.
I edited your posted so everyone can read them, if you copy and paste can you click paste as plain text it allows those on any theme to read your posts then.
(10:th-Mar-2019, 09:41:53)Rusty2009 Wrote: The ramps I have are slightly too small for the tyre I still use them just make sure I centre myself on them properly, granted I don't do anything major with them.
Ok Thanks
