» Members: 12,317
» Latest member: lar77
» Forum threads: 4,566
» Forum posts: 49,709
Astra J 2014. Electric st...
8:th-Sep-2025, 21:22:49
Factory Reverse Camera, A...
Forum: Retrofit How-to's
Last Post: obsidian
30:th-Aug-2025, 20:00:16
» Replies: 34
  2013 GTC 1.6T Crankcase vacuum
Posted by: Johnh - 23:rd-Apr-2020, 09:05:22 - Forum: Mechanical - No Replies
Hi everyone from Australia!
Hope your all well and keeping busy with your Astra's, I know I am.
I'm here looking for info on the crankcase ventilation of my GTC. I have serious a vacuum in my crankcase/head causing bad whining or squealing when the car is warm.
Its definitely the vacuum causing the squealing as when I remove the dipstick or oil cap it stops dead.
I'm thinking a PCV valve is causing this but im unsure on how the system works on these cars.
On the camshaft cover is a pipe going to the turbo intake (PCV I presume). The crankcase vacuum is still there when disconnected from the intake so it's not this PCV.
There must be another PCV on the inlet manifold past the throttle body, does anyone have any information on the vacuum system?
I thought maybe the auxiliary vacuum pump on the cam shaft but its not that when isolated either.
Any advice would be much appreciated, thanks guys!
Posted by: Johnh - 23:rd-Apr-2020, 08:57:33 - Forum: Astra-J/GTC Technical - Replies (1)
  service parking assist and tpms not working
Posted by: kevinmcken1404 - 22:nd-Apr-2020, 23:27:21 - Forum: Astra-J/GTC - Replies (3)
hi guys
im new to the forums,was just wondering what i might have done wrong with wiring up my dash cam to green and white wire before it gets to back of rear fuse box.
seems its knocked out the parking sensors(getting the service parking assist warning on dash)and the tpms is not working,ive checked the fuse for parking sensors and its still fine plus theres a 12 volt supply to it also.
any help would be appreciated
Wink Exhaust systems
Posted by: SRILiam - 22:nd-Apr-2020, 19:10:24 - Forum: Astra-J/GTC - Replies (2)
Hoping someone can shed some light on this. I have seen a cat back exhaust system for a gtc 1.6 turbo. Now my car is a 5 door 1.6 turbo so would it fit on my car as I cant find a system for it. Looks the same in the pictures but not sure. Maybe someone knows if the standard exhaust systems are the same part number?
  NAVI 600 Lost Navigation Voice.
Posted by: Roden - 21:st-Apr-2020, 15:09:56 - Forum: ICE - Replies (3)
Hi all, having a very strange issue.
Not long ago i updated my NAVI 600 to 2019 maps, all appeared fine for weeks. Then i had to pop the battery out as it went flat in all this CV business, could not charge in the car as i have to park a way away.
Now im all back in and running, i have noticed i have no sat nav voice, everything else appears fine.
Ive tried a factory reset, and even pulling the fuse and restarting, and nothing.
Also tried the old card.
Any Ideas.
Thumbs Up HID Kit Questions
Posted by: tez162003 - 20:th-Apr-2020, 14:17:33 - Forum: Electrical - Replies (4)
I have been doing some hunting around for a HID kit for my Astra GTC. Seems like most the information is around on the forum in various threads over the years but nothing that makes it 100% clear (at least to me).
Am I right in saying the following?
1. Astra GTC have the correct headlight units as standard (projectors) to allow legal installation of HID's?
2. You should get the 35w HID kit otherwise there may be MOT issues?
3. The bulbs you need are HIR2 (9012) and NOT H7's.
4. Installation requires removal of the bumper / atleast removal of the headlights?
And finally a couple of questions I am not 100% sure on?
5. Other than kits from HID Direct (who seem totally out of stock), what kits have been tried and tested on Astra GTC's to work faultlessly and not cause Canbus errors?
6. Ever heard of the stealth kit? Stealth Kit (Autobulbs direct)
7. What colour output is most common / not likely to get me flashed at every 5 seconds?
Any help is much appreciated.
  Inner rear light
Posted by: Kiel0777 - 20:th-Apr-2020, 10:13:55 - Forum: Lighting - Replies (9)
Hi inside the rear back light cluster it looks really loose is this normal?
  Coolant level
Posted by: Kiel0777 - 19:th-Apr-2020, 15:58:10 - Forum: Mechanical - Replies (2)
I have a astra j 2.0 cdti elite does it Come With coolant level sensor as standard?
  wiring info
Posted by: niteram - 18:th-Apr-2020, 11:00:10 - Forum: Request for information - Replies (2)
Hi, does anybody know how the electric vacuum pump (for the brakes) is wired?
there are 2 wires (Red and Black) from the pump which go to a large connector block with 3 wires
what does the 3rd wire do?
I'd guess that red and black are live feed and earth, so is the "connector block" actually a relay and the third wire a trigger feed?
a wiring diagram may help if anyone has one.
the parts catalogue I've looked at shows the connector block coming with the pump assy
[Image: 247953.png]
many thanx
  Gtc 2017 1.4t 120 front brake disc size
Posted by: Nathan191210 - 17:th-Apr-2020, 21:08:38 - Forum: Astra-J/GTC - Replies (2)
Could someone let know what size brake discs are on the GTC  1.4t  120 2017.
