| Welcome, Guest |
| Forum Statistics |
» Members: 12,319
» Latest member: Pajda223
» Forum threads: 4,568
» Forum posts: 49,721
| Latest Threads |
From $50 to $5,700: The B...
Forum: Vauxhall General
Last Post: Jonathaneuk
20:th-Feb-2026, 04:07:48
» Replies: 5
Binance Mining Paid Me $9...
Last Post: conyas92
19:th-Feb-2026, 19:25:28
» Replies: 5
| Changing steering wheel badge |
Posted by: Kieran - 6:th-Nov-2016, 21:37:49 - Forum: Astra-J/GTC
- Replies (7)
Looking at swapping all the badges on my GTC to Opel badges (cleaner look imo) Im guessing the 2 badges on the bodywork are gonna be a pretty straight forward swap, havn't had a proper look yet, but for the steering wheel am I going to need a new wheel or airbag?
Looking at the way the badge is set in wheel i'm assuming this is the only way round it, any of you guys swapped the badges over and have any info for me? Cheers
| Deactivate the windows opening from keys |
Posted by: bruce_19 - 6:th-Nov-2016, 16:50:48 - Forum: Electrical
- Replies (4)
Does anyone know how to deactive the windows opening from the key?
I have been through the options through the radio but I can't find it could be me being daft lol.
If some of you have Facebook you have seen my post about my windows being open all night and the footwells and seats being soaked.
I have now used a carpet cleaner and currently have the car running in the drive to help dry it out for tomorrow.
| ECM "Upgrade" Recall Causing Performance Issue? |
Posted by: Black_Cat - 6:th-Nov-2016, 15:01:33 - Forum: Astra-J/GTC
- Replies (4)
I had my 2013 Astra 2.0cdti in for service last week and was told it had a recall to "upgrade the cars software". I've since learned this is an upgrade to the ECM software.
Since the service it simply does not feel like the same car. I'm having to change down gears to get up hills I've driven everyday without the need previously for example.
Does anyone know what is involved in this upgrade and if it could have altered my car's performance? I believe the upgrade may have something to do with emissions.
If not the only other thing that happened is the paperwork showed my car had actually received the 2012 1.7 service. The dealer said this is not an issue as the service (the 4th) is the same for both. Is this correct?
Thank you very much in advance for any advice/information given.
| coolant issue |
Posted by: Shorty S91 - 5:th-Nov-2016, 23:17:25 - Forum: Astra-J/GTC Common Problems
- Replies (5)
Evening guys,
Ive been keeping an eye on my expansion tank for a while but yesterday I went to the the kids to nursery and was prompted with a low coolant level warning. So i checked to see where it was at and there was just under half when I always keep my tank topped up.
I took the cap off and started the car to see if there was perhaps an air lock in the system. Ran the car for about 10 minutes and held it at 2000 rpm for about 2 minutes. The level returned to normal.
Checked it again today and the level had dropped again. there is no staining around the water pump and I cant see any wet patches on the ground or in the engine bay. The car is not over heating and still runs smooth however I have noticed a small amount of bubbling coming through the return pipe back into the expansion tank.
Any ideas???
| looking for |
Posted by: tucpal - 4:th-Nov-2016, 19:34:39 - Forum: Astra-J/GTC
- No Replies
does anyone on here have a factory opted navi 600 with factory rear camera
must have come out the factory with these options
i need a bit of info from you if you can help thanks
