» Members: 12,319
» Latest member: Pajda223
» Forum threads: 4,568
» Forum posts: 49,721
From $50 to $5,700: The B...
Forum: Vauxhall General
Last Post: Jonathaneuk
20:th-Feb-2026, 04:07:48
» Replies: 5
Binance Mining Paid Me $9...
Last Post: conyas92
19:th-Feb-2026, 19:25:28
» Replies: 5
  1.6t performance mods
Posted by: SteveMcS - 4:th-Apr-2017, 21:12:06 - Forum: Astra-J/GTC - Replies (2)
Just curious as to what performance mods were available for the 1.6t. I don't here about this engine much and modifications are even rarer.
I'm currently planning what I want done so I can start putting together an order of things to do and so far my list is:
1) Exhaust (still to decide cat back/ full system etc)
2) Intake
3) FMIC
4) Stage 2 Remap
but I was wondering if there's anything extra I can do to get a bit more out of her. Any body know of anyone fitting bigger turbo? injectors? anything else?
And before the "should have bought a VXR" comments, my circumstances were different when I was buying. Plus, the build is often more exciting for me than driving so i'd prefer to buy an underdog and modify it over buying a fast car in the first place.
Any help appreciated! Thanks in advance!
  single din in astra j
Posted by: micko - 4:th-Apr-2017, 09:03:56 - Forum: ICE - Replies (4)
hi guys just got my astra j 1.7 cdti eoflex s/s 130ps nice car.only problem is the cd400 what a load of crap
would like to put my pioneer dab in from my Astra h? is it possible,seen the facia adaptor but its double din
anyone done it,cheers
  Astra light in footwell
Posted by: Jon_es - 4:th-Apr-2017, 01:57:38 - Forum: Astra-J/GTC - Replies (2)
So i have had an idea, so in some bmw's there is a light which lights the footwell but what we could do is put a light (like the boot light) in the centre console next to the gear stick and wire this into the light around the gearstick.
[Image: f21d412ce76dbb8c06bd4ef92d816b2c.jpg]
  Trip Computer on Mid-Level Display?
Posted by: A10HUY - 3:rd-Apr-2017, 09:50:43 - Forum: Astra-J/GTC - Replies (4)
Hi there,
I have noticed loads of different dis-activated lights on my mid-level display, one of which is a light of a fuel pump.
Does anyone know if there is a mpg/trip computer that can be turned on in the mid level J display? I wouldn't see that Vauxhall would put lights and things in there if they didn't do anything.
Cheers in advance
  engineering menu returns to default mode
Posted by: Saxito@Tech - 1:st-Apr-2017, 19:54:43 - Forum: Electrical - No Replies
I modify "sharx" and "high cut"in the hidden engeneering menu, is two functions in" tuner test", but when the car go off, the menu returns to before state.
Do Someone know how to resolve the problem?
Is there any solution for this?
Sorry for my bad english. Thanks.
The sharx funtion in 0 adjust resolve the bad reception an lost signal un fm...
  Does the a17dte 1.7 engine have swirl flaps?
Posted by: rbull51 - 1:st-Apr-2017, 17:15:26 - Forum: Astra-J/GTC - Replies (3)
I have seen a few posts about swirl flaps on diesel engines becoming stuck or faulty. Does my engine have them, if so how can i locate them?
  Dry, almost grinding type noise from front wheels / discs area
Posted by: rbull51 - 1:st-Apr-2017, 17:03:21 - Forum: Astra-J/GTC - Replies (2)
I have noticed a strange noise on my astra j. The noise sounds like when a brake disc lip may be slightly rubbing / touching the caliper. However, it is not this making the noise. The noise happens all the time. It doesnt change if i brake, turn left or right and it doesnt change with clutch or gear changes. If i push the car when it is off i can still hear it. Possibly from drive shaft area?? Has anyone else had this?
  Seen washers
Posted by: andiman t - 1:st-Apr-2017, 08:36:29 - Forum: Astra-J/GTC - Replies (6)
Has anyone else had problems with screen jets not hitting screen
  Turn Signals and Wiper Stalk Switch
Posted by: Doraemon02 - 1:st-Apr-2017, 02:53:29 - Forum: Astra-J/GTC - Replies (1)
Hi Guys,
So my switches to turn on/off the turn signal and the wiper stalk make a cery flimsy noise when I put them on/off.
The one for the wiper is the worse... as if something is broken.
Is there anything that I can do?
Enviado do meu SM-G935F através de Tapatalk
  Cd500 navi
Posted by: Davy20121957 - 31:st-Mar-2017, 19:54:19 - Forum: Retrofit Research - Replies (5)
Can anyone help with this upgrade from cd400
to 500navi I'm trying to fit to my 60 plate Astra
I have taken many different looms from insignia with 800 nav
Mokka but still can't figure out how to swap what wires to swap around
Messaged Rusty ,, had a look on global 'tis ,, still can't do it
I also have state looms for insignia a dash loom for mokka
Spare USB ecu dab ecu mokka interior mirror with camera that I don't need
Any help with this would be great
Davy
