| Welcome, Guest |
| Forum Statistics |
» Members: 12,318
» Latest member: Josephcic
» Forum threads: 4,568
» Forum posts: 49,721
| Latest Threads |
From $50 to $5,700: The B...
Forum: Vauxhall General
Last Post: Jonathaneuk
Yesterday, 04:07:48
» Replies: 5
Binance Mining Paid Me $9...
Last Post: conyas92
19:th-Feb-2026, 19:25:28
» Replies: 5
| Fuel consumption - 1.3 CDTI |
Posted by: mw2299 - 18:th-Sep-2017, 22:22:30 - Forum: Astra-J/GTC
- Replies (3)
I've got a 1.3 CDTI and the fuel consumption seems really quite bad to me? The car is completely standard atm, yet out of half a tank I'm only getting 150-160 miles? I haven't filled it up yet, and I don't really do it unless I need to, but I can't see why it's so bad. The car has FSH and was serviced 11 months ago. Any ideas?
| Injen indiction kit |
Posted by: Daniel199025 - 18:th-Sep-2017, 20:14:20 - Forum: Astra-J/GTC
- No Replies
Guys have been searching for an induction kit for my Astra and the only suitable one I've found is a kit by injen has anybody got one or any experience with them thanks
| Problem with DRL |
Posted by: mw2299 - 18:th-Sep-2017, 15:05:09 - Forum: Astra-J/GTC
- Replies (5)
Hi guys
I have an issue with my Daytime Running Lights. When the light switch is set for just the DRLs, the passenger side's DRL doesn't work at all. If I switch to the park/side lights, they work fine (and are dimmed as they should be). If I switch to dipped beam, then both the DRLs are on along with the dipped beam. Could it still be the bulb or is it something else?
| Engine sound |
Posted by: Lukedent1234 - 18:th-Sep-2017, 09:26:28 - Forum: Astra-J/GTC Common Problems
- No Replies
Hi I have a 12plate 1.6t astra gtc and the engine sounds like it is about to overheat or the fan is working overtime, it is very loud and my friend said that when I was outside his house it sounded like a fighter jet, I have checked the water levels and they are all fine could sound one please help me
| Engine noise |
Posted by: Lukedent1234 - 18:th-Sep-2017, 09:21:37 - Forum: Astra-J/GTC
- Replies (3)
Hi I have a 12plate astra j gtc 1.6t when engine is warm it sound like it is over heating or the fan is working overtime, I picked my friend up from for work this morning and he said that he could here my car from inside his house and it sounded like a fighter jet, could somebody please help me or have any ideas on what the problem may
| Rear brake disc size |
Posted by: Daniel199025 - 17:th-Sep-2017, 22:15:55 - Forum: Astra-J/GTC
- No Replies
Hi everybody. Am just wondering if anybody can tell me what size rear brake discs I need as when I order them it shows me 2 different sizes. My car is 2012 Astra gtc 1.6 180hp cheers in advance
| m072 satnav |
Posted by: Jhill7168 - 17:th-Sep-2017, 19:11:27 - Forum: ICE
- Replies (3)
hi guys quick question,
what satnav does everyone use of the m072 cus i think igo is awful cant even put in a postcode so its a nightmare to use, i wanted to use google maps but i dont no how or if you can use it just using gps as i cant really use my phone as a wifi hotspot as i have a rubbish contract and only get 1gb of data, can anyone help with a better one that just uses gps or can you even use google maps wit just gps and if so how?
thanks in advance
james
| Corrosion on underneath of Astra |
Posted by: irishastraowner - 17:th-Sep-2017, 13:55:55 - Forum: Astra-J/GTC Common Problems
- Replies (4)
Their seems to be a good bit of corrosion on the underneath of my opel astra (2012 model). Has anyone else experienced this? Were they not treated with a high quality corrosive paint. I don't drive through water that would touch the underneath of the body. I do live on the west coast of Irl so their would be an element of salt water but surely it shouldn't cause this so noticeably.
Any suggestions as to how to rectify this?
I would post pictures but for some reason my attempts to upload them fail.
| Information display speed doen't save |
Posted by: abba34 - 16:th-Sep-2017, 08:30:03 - Forum: Astra-J/GTC
- Replies (2)
When i select menu 7 for displaying the speed, it will not be saved when i turn off the igision for about 10 minutes, and i have to select it again when i start the car.
Is there any way to save this setting?
