spacers wheel eibach
eibach wheel spacers
as the title says anyone used these
http://www.ebay.co.uk/itm/OPEL-ASTRA-Spo...258588afcb
not really sure if the origanl studs will need to be cut
I know Jamie from *** has some fitted and is really happy with the outcome
i remember that could you ask if he cut the origanl studs
i am sure he swapped them for smaller ones
One thing that confuses me watching the cops on t.v they pulled a car and it's wheels were sticking out past the arch and gave him a defect ticket.
Yet I've seen loads like it and the cops do nothing.
So is it ok?
It depends on which part is sticking out I know the top part has to be inside the arch
come MOT time it may be a problem if they stick out to much
but 20mm a side should be ok
Jamie had to fit longer studs to accommodate the spacers and not had any issues
Ah ok.
thanks baz i may get the 15mm then
  BiTurbo spacers eatmybogbrush 0 2,426 9:th-Jun-2021, 03:06:46
Last Post: eatmybogbrush
  Steering wheel angle, esp, power Steering smoky-jr 3 7,422 6:th-Jun-2021, 18:23:26
  Broken wheel stud Euroshopper 1 3,723 6:th-Oct-2020, 07:08:18
  Steering wheel from Astra K foxydimsi 2 6,858 1:st-Oct-2020, 06:49:56
  GTC limited edition alloy wheel paint code Nathan191210 5 7,303 1:st-Aug-2020, 19:22:43
  2017 GTC Limited edition - Front wheel noise Nathan191210 4 6,583 12:th-Jul-2020, 07:37:10
  space saver wheel Gary13 5 7,249 24:th-May-2020, 19:02:57
Last Post: Gary13
  Squeak when turning steering wheel Rusty2009 12 25,426 12:th-Sep-2019, 21:45:35
Last Post: Boycey1969
  Lowering and wheel spacers twinpipes 1 4,350 28:th-Jul-2019, 08:43:33
  Astra VXR heated steering wheel THEHITMAN 26 28,364 10:th-Mar-2019, 09:34:44
