2:nd-Jul-2014, 20:36:17
does anyone know how many fuses are fitted in the fuse box for the ECU on the 5-door J? am I right in thinking its fuse no.1 and fuse no.15?? anyone know why two fuses are referenced???
ecu fuses?? or fuse |
ECU fuse or fuses??
2:nd-Jul-2014, 20:43:31
I was just about to link to that lol but yes fuse 1 & 15 anything wrong?
2:nd-Jul-2014, 20:48:30
just going to reset the ecu and see if I can get rid of a slight pinking at around 1300/1400 rpm...think it is more heat related to be honest as the hotter the air temperature the worse it sounds...its a long shot, but got fobbed off at dealers, so if it doesn't work then I know a good garage that will investigate further.
2:nd-Jul-2014, 20:50:51
by way do you know what fuse 1 is for and what fuse 15 is for?? and dont say ecu
2:nd-Jul-2014, 20:55:17
tucpal Wrote:probably best to get that looked at with the proper tech then thats what I think, cant believe dealers, one of their guys came for a drive and just said 'cant believe your bothered about that, its nothing, if it was a problem you would get a MIL light'....not impressed but then again it is the dealers
2:nd-Jul-2014, 20:57:50
tucpal Wrote:you may need to remove 53 as well 53 not fitted in mine :eek
2:nd-Jul-2014, 21:00:12
Some models will have fuses others don't mate. It all depends on engine and options fitted.
2:nd-Jul-2014, 21:02:35
cheers guys....great info as always
2:nd-Jul-2014, 21:05:30
Rather than remove the fuses why not pull the neg off the battery and leave it for a few hours, will give the same result.
3:rd-Jul-2014, 20:12:08
hasnt made any difference....looks like a trip to local garage for a second opinion
Possible to install boot fuse board? | Find_By_SQL | 3 | 2,225 |
3:rd-Jul-2020, 07:44:19 Last Post: Rusty2009 |
Rear Fuse Box | sheppy1 | 4 | 4,495 |
19:th-Feb-2015, 05:04:23 Last Post: tucpal |
Fuses | richje100 | 4 | 4,354 |
31:st-Dec-2014, 18:37:53 Last Post: Rusty2009 |
